Hey guys. So my R34 GTT has a custom 3.5” exhaust (done by previous owner) with a high flowing cat, and then just a Varex cannon muffler on the back. The car does drone alot and is really loud even on highway driving just cruising, as you can imagine due to the Varex muffler basically being a straight through with the valve open. As much as i love a loud RB, it can be a bit much with no other muffling in line and just driving casually. I wanted to lower the volume output on the exhaust a bit, as well as remove the drone (probably a way to do both at once), and was going to do it all myself as I am a fabricator and have done exhaust work in the past, so the fab work isnt my issue, im just not sure on the right product or type of product to use to get the job done, and i doubt an exhaust shop would be wanting to help me as they wont be making any money from helping me, unless they supplied the product? Anyway any help or guidance in best way to approach this would be awesome
Thanks in advance
Go to SP mufflers and get the muffler of size you want and make a nice mid muffler.
It's about that simple! I have 2x 3.5 Magnaflow straight through Mufflers and while it's pretty loud with the Varex open, it's quiet enough with the Varex closed. You can also buy off the shelf Magnaflow straight through mufflers as well.
You also have a turbo to quiet the car down too. Don't overthink it. Buy my extra Magnaflow muffler sitting on a shelf doing nothing (buy it new, ignore this part)
Cheers. I more want it quieter with the varex open. I only have the varex closed when i start up and roll out the driveway to keep everyone happy on days i take the car to work at 5 AM or come home late. So just a mod muffler will do tge trick? Something like that would require a retune hey?
I did say "2x Magnaflows" then referred to a Varex. So to un-confuse that, my rear muffler is hot-swappable with a Varex.
When I had a RB Turbo, I had the 2x Magnaflows, then went LS and though "Oh that's way too loud" and ordered a Varex.
A mid muffler will definitely help a lot, even if straight through. SP Mufflers can make anything as big or as small as possible, which will help even more. Looking at my own exhaust I could make the muffler twice as long if I wanted to. Or you could go crazy and get 2x mufflers from SP and full every remaining space with muffling.
In my experience closing the Varex makes the car run VERY rich (obviously). I'd say adding a muffler *will* affect things, on a technical, physics level, but I don't think you'd need a retune as the actual effect would be the car running a *tiny* bit richer due to more restriction, on a strictly physics level, but you kind of don't have any option if you want the car to make less sound.
  • Like 1
Yeah great. Just got off the phone with SP, and will see about getting one of their mufflers to weld in in the next month or two. For me the varex is to get me out of the driveway, down the road and thats it. It stays open 99% of the time driving as it does definitely run rich with it closed as you said, and restricts the boost build up. Thanks for your help
  • Like 1
33 minutes ago, GTSBoy said:
Straight thru's have so little restriction that it's almost certainly not worth worrying about effects on tuning. Even a centre offset shouldn't upset things, but would be noticeably more effective (quiet).
Thanks mate!
I'm struggling with a similar issue on an RB26. Make sure you know whether it's volume or resonance. Mine seemed louder when cruising compared to at idle. I downloaded a decibel meter for my phone. Take my less than scientific results with a couple grains of salt, but the decibels were the same at idle and at cruise. Mine seems to be a resonance problem. At 2500-3500 rpm, the sound is different and "louder" to my ear. I think it's vibration from the pipe, the car body, the floor or something creating tone.
Anyway, consider that it may not be strictly a volume problem.
  • Like 2
Yeah i get what you mean. Mine thought i wouldnt mind being a bit quieter overall as well as have the drone taken out is more what i was trying to say. Im going to start with a mid muffler, and go from there
It can be worth experimenting with adding a Helmholtz resonator to some systems, particularly if it is one tone that drones excessively. This is a short(ish) length of pipe teed off the side of the main pipe, ending in a dead end. The length tunes the frequency at which it works. You have to experiment to find the right length. There's a recent youtube vid where someone did it, might be worth a look.
Yeah ive looked into those. I saw one guy who made his adjustable so he could fine tune it, but theyre a decent amount of work to get right and they only do one particular range of frequencies. I feel like if youre not worried about losing some overall volume in your exhaust (like me) and want an easy solution, slap a decent muffler in and that should do it, as a muffler should take out more of a frequency range but also you lose some of the volume, which is fine for me
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
