Hi all,
For my '98 260rs...
The odometer LCD occasionally turns blank or gives me only the bottom half or top half of the numbers. It's intermittent, which leaves me to believe it's a dead solder or loose wire somewhere. The odometer itself works. When the screen comes back, kms have been added to the trip and overall meters. A couple questions:
  1. Is this a known issue with the Stagea? I didn't see it pop up in my quick search, but that could be my searching skills.
  2. How accessible is the LCD screen in the cluster? I'm hoping it's a remove and replace type situation versus cracking open the whole housing.
I'm hoping you all can narrow some of my initial troubleshooting. Any experience or opinions would be helpful.
Hi mate, I have never had an issue with the odometer in mine (450,000+ klm now) and can't remember another post about it. Still, your description of the likely cause sounds spot on, so an electrics repair is probably the next stop.
Yay. I'm the lucky one who got the bad LCD. Only 138,000km or so on this car.  馃檮
On a non-Nissan car I have, similar issues were related to failing cold solder joints. At least with the Stag, I'm not losing my speedometer, odometer, gas gauge, and temp gauge. I guess I get to go into the dash at some point. I'm not overly concerned about it, but it's annoying. Seems to be happening more frequently in the past couple weeks too. Not sure if that's the summer heat causing hassles or the problem genuinely getting worse. Bleh.
Edited by Kip
corrected typos
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
