My '96 r33 Skyline has Rota GTR, 18 x 9.5 inch, ET30 on the front and Rota GTR-D, 18 x 9.5 inch, ET12 on the rear. (Put on by previous owner)
The 12mm offset is throwing me for a loop. Is it due to the "deep dish" design of the wheel that the offset it so low? Or is it actually that low on the rear normally?
If I were buying a set of new wheels, could I put 30mm offsets on the rear and reasonably expect them to fit?
I have GTR Brembos and 370Z rotors (355mm/350mm) if it matters.
Thank you.
Edited by IXMandalorianXI
https://www.sau.com.au/forums/topic/485619-wheel-offset-has-me-confused/
The offset doesn't really have anything to do with dish directly. I mean it kind of does but it also doesn't, it's only tangenial.
The offset is purely how much offset (get it) the mounting face is from the CENTER of the width of the rim.
I.e, the mounting face would be directly in the middle of the 9.5inches if it was a 18x9.5 ET0 rim.
Given it is a +12 rim, the mounting face is 12mm further away from the center (to the outside of the car).
Your fronts are +30, so the mounting face is 30mm further away from the center (to the outside of the car).
I would wager this doesn't look right, because most skylines generally have the same with guards front to back. So I'd think your fronts look significantly more sunken in than your rears. I'd wager by about 18mm, or so.
  • Like 1
I should clarify that the previous owner put the wheels on, so Im not entirely sure what he bought. I was searching the Rota page and found these two as the only matches. It did not occur to me that perhaps they sell these wheels with different offsets.
I guess the best way to solve this is to take the wheels off and measure them from the inside to be sure.
Ok, maybe I'm approaching this the wrong way. I'm trying to buy new wheels, and I was having trouble finding the exact offset needed for my r33 GTST Spec 2. I figured trying to reverse engineer the wheels already on the car was a good method, but maybe I'm over complicating tings.
I tried using this thread, but I was unsure how to translate what others had and their set-ups versus my own. I know the wheels I have right now are 18 x 9.5, front and rear, so it's just the offset that's really throwing me for a loop. I'm not sure if stock GTST offset would be the correct answer because again, I have GTR calipers and 370Z rotors. I've replaced the rotors recently and taken the wheels on and off enough times to know I don't have any spacers.
You are right, there are 2 ways to approach it, you can go for wheels known to fit well on the car, or measure from what you have.
If you jack up the car and check the distance from the inner side of the tyre to the first obstruction (generally the control arm, or a shock) and then do the same from the outside of the tyre to the guard, that tells you how much wider you can go or what offset you can use.
I'd note that 9.5 is huge on the front of a 33 gtst, if they are not scrubbing anywhere including fuil lock then don't change anything about the front width and offset.
  • Like 1
It's very possible my measurements are wrong as I did measure with the wheel and tire still on the car. It's possible I didn't judge inner gap correctly and ended up adding width. I'm eager to buy new wheels, but I think I might be putting the cart before the horse. The best thing to do this right. I can take off the wheels off, I might even just have the tires taken off and do some proper measurements. It won't cost me much, if anything, and will save me a whole bunch of headache in the long run.
36 minutes ago, hardsteppa said:
The offset of the wheel is usually stamped on the inside of the rim. So just pull the wheel off and see if it's marked as such.
Thank you for the heads up! Will definitely take a look!
I am amazed that you have 9.5 inch wide rims on the front! What size tyres are they paired with? How much negative camber do you run? What has been done to the guards?
Edited by Murray_Calavera
TBF, I had 9.5 +27 on the front (and rear) of a 34 which most consider to be much the same as a R33.
It fits exactly where a 18x9+30 otherwise would, if you run the same size tyre on either rim. I had a 265 on the front of mine and the tyre sidewall on the inner is the limiting factor.
I ran like -1.5 camber.
I am putting 9.5 +30 into the 'feasible' camp.
Will still be 18mm inset from the 18x9.5 +12 on the back though.
I suspect one of these wheels is not the sizes in the original post, or it looks wonky. Pictures plz, OP, I must know lol
  • Like 1
I can't remember the offset of the wheels, but my street rims are 17 x 7.5 front 8.5 rear. My track rims are 17 x 8 front 9 rear.
This seems like madness to me as my 17x8 rims rub with 235/45 tyres on them. The street rims however are perfect.
I do run 19mm steering rack spacers which makes things a little trickier, but yeah I just can't picture fitting another 1.5 inches of rim in there lol.
You all are making me think I incorrectly measured the wheels lol. Will definitely remeasure everything once they are off the car later this week.
3 hours ago, Kinkstaah said:
Hey OP, wheels look good, previous owner had the right idea, drive and enjoy car :D
Oh they look great...they roll...less great haha, front driver-side is minorly bent. Not dangerously, but enough to be really annoying. Hence, this adventure to buying new wheels (or rather at least one new wheel). Possibly to buy four new wheels if the right ones jump out at me, but definitely keeping them white no matter what.
  • Like 1
The tyre fitment will be important here. You may be able to fit a super wide low offset wheel in but then you will be limited to stretch tyres..
I personally run a 18x9.5 +11 (rear) and 18x9 +18 (front) on my R33 and the tyres are only slightly stretched (check my build for pics). However, mine is definitely on the more snug fitting side..
IMO a 9.5" rim size (all round) id say a +20 to +25 on the rear and +25 to +30 on the front would be a reasonable fit with some room for decent tyres..
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - My car has heaps of small dents, that definitely need filler but are you also sanding the area to 240 grit to fill it in with filler? I always thought you have to go to bare metal for filler to stick but that contradicts the point then that you can put filler on epoxy primer.  If you aren't going to bare metal, AND not putting epoxy primer how are you making the dent stick to the paint?
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
    • Most driving should* be done on one side of single lane divided roads. In the RHD world, you drive on the left side of the dividing line and the road is probably cambered equally on both sides. So your side of the road slopes away to the left. The same is true for the LHD world, just everything swapped to the other side and opposite slope. With a perfectly neutral, straight ahead wheel alignment designed to drive straight on a perfectly flat surface (or at least one that is level on the left-right axis, even if it has some slope in the fore-aft axis) you will not be able to drive on a cambered road without the car wanting to drift down the camber. You will need to add steering input in the opposite direction all the time. This is annoying. The solution has always been to set the camber and/or the caster to produce a continuous turning force in the opposite direction of the camber. The car will drive straight on the kind of camber for which it was set up, presumably as described in the top paragraph. But.... when the car is set up this way, as soon as you get into a lane, usually on a multi-lane surface road or highway, where the camber is not as presumed during setup, the car will usually pull to one side. In the RHD world, if you are in the fast lane on a big divided road, you are probably on the opposite camber compared to what the car was set up for (ie, sloping down to the right) and the combination of the setup and that camber will make the car want to go right pretty hard. Even a perfectly flat lane will tend to want to go right. There's no getting around it. Civil engineers who know their stuff (which is not an assumption that can always be made) will attempt to keep the variation in camber across a multi-lane road as small as possible, and if they can will attempt to make the fast lane as close to flat, or even cambered in the same direction as all the other lanes. This takes a lot of planning for drainage, control of levels, ability to deal with the elevation changes that occur at road junctions, etc etc. So it's not trivial to get it right. When they do make it work, then the annoyance is reduced, along with tyre wear, fuel consumption, etc. In theory, the civil engineers are supposed to worry about those aspects of road design also. * This used to be true, but now with very large highway systems, even just multi-lane surface roads running everywhere, it is less true now than it was, but the old assumption is the basis for describing the phenomenon, so let's just run with it for the moment.
