R32 GTR front Differential and prop shaft
Hi all,
My 1990 R32 GT-R has developed a bad knocking sound coming from the what I assume is the front differential (the reason why I assume this is when I pull the fuse for the asetta the knock disappears put it back in and it comes back and yes the transfer case and gearbox has fresh oil in it), the uni joint on the front differential side was broken bad it would have been causing massive vibrations into the pinion gear,
has anyone experienced this before? And is anyone selling a front differential Center complete with pinion and crown gear ?
For the drive shaft I can’t find any driveline workshops in SE QLD that will put a new uni joint on the front prop shaft as they are a staked uni joint no one wants to touch it 😭
does anyone have any recommendations on any workshops that can replace the uni joint ?
sorry if this has been posted before I couldn’t find anything using the search function for this exact issue
thank you
NSM32
sorry for the bad photo, yes it’s missing a bolt I took the photo while removing the shaft to take to a workshop to try and get it repaired
3 minutes ago, GTSBoy said:
Spicers
Do you have any details for them ? Location, contact number ?
Hardy Spicers. Only the single largest and most well known manufacturer and repairer of power transmission shafts in the whole country. They are present in most capital cities, and many regional cities.
They will build you a complete new driveshaft if need be.
There are also automotive focused workshop/manufacturers, like GJ Drivelines in Melbourne. I struggle to believe that there is not someone doing similar work in Brisbane. A quick google shows Universal in Brissy, Driveline Services in 2 locations in Brissy, someone else on the Goldy, Mal Wood in Warwick....
Never heard of them they obviously aren’t in Australia….
no shop that I’ve been to will touch it as the shafts are spiked….
You shitting me? They have a location in Brisbane.
Who cares? Cut it off and make a new end. That's why I said Spicers in the first case. When you want to fit an RB25DET gearbox in an R32, for example, you need to cut and shut the front half of the tailshaft using the end from the RB25 geabox that has the matching spline. Guess who does that? Spicers.
You want a brand new tailshaft? Made from steel? Aluminium? Maybe even CF? Then you go to someone like GJ and they will build it from scratch. Putting a brand new universal onto the end of a tailshaft is not difficult. You just need to go to a proper shop that can weld and balance such things. Not Majid's mechanical and kebab shop on the corner.
The other places I listed in Brisbane sound like it should be in their capability list also.
  • Like 1
Your arrogance is astounding
firstly it’s not a “tailshaft” it’s a prop shaft from the transfer case to the front diff
secondly every drive shaft shop I called including the ones you mentioned above refused to touch it..
pull your head out of the sand if you have no helpful information don’t bother commenting
 Share
    • Yeah mate, I’m not 100% how much damage this water has done to the crank and internals. At the moment my mate is sending me whole inlet man with injectors rail to bolt on.  in the future it’s gonna get a decent amount of boost prob around 400-500hp so this motor is just gonna get it on the road and registered.  see how it goes. Stage two turbo is still a long way off.
    • You should throw rebuild kits at the injectors while they're out...they pretty much need it anyhow at this age in life.. 😃
    • How much is it pushing down on the PS belt? What if you slot the top hole in the mounting bracket so it can rotate toward the PS pump and raise the idler enough to get it off the AC belt. In my experience with some mates drift cars, the belt gets flicked off on the sudden decrease in crank pulley speed on the limiter or downshift in a dog box. We came up with a good fix for the 2J using some Mazda timing belt idler that was just resting on the belt and stopped the belt coming off on some cars that were chronic for it.
    • Might be a stupid question, but if you wanted to just change the face plate (not the whole cluster) to a higher km one, how would one go getting the cluster recalibrated or it doesn't work?
    • Ok, bit of an update with whats working.. - i think it's the fuel staying on (when i perhaps shouldn't be) at zero demand that causing the lungeing. I say this because when playing around and trying to learn about fuel cut/zero demand settings i got it to lunge bad at 30-40km/h whilst decelerating. It's almost as if the fuelling is fighting the natural engine braking and the chassis 'bounces' against the backlash in the driveline (diff especially), making it worse. I had a forester GT (w/aftermarket ecm) that used to do it, and i couldn't work out why. - map prediction works awesome with drivability, made a big difference straight away.   I'll keep working on it, esp the idle quality with and without aircon.    Thanks again for the help lads!
