Overheating issues
Hi all,
so after my hks ss turbo complete setup with all the trimmings and a tune … I have sometimes my ecu cutting boost most likely because of water temps going too high… safe guard in the tune. Suspect ppl are running aftermarket water temp gauges and sensors as the stock one is very inaccurate?
just a background it’s currently 36 degrees in the day and 90 percent humidity here. I had some issues after a 45 min drive at 6500 1.4-1.5 bar.
What is everyone doing to get around this issue bar changing up to a more advance fan system? I have already upgraded the radiator to a more efficient one. But I guess I could go even better higher level. One I am running actually came with the car.
heard these motors have serious over heating issues especially if u stop and start in traffic and it’s very hot.
thanks
So you THINK it's overheating, and are only GUESSING it is, because you THINK the ECU is hitting a heat cut?
Do you have any datalogs to prove this?
Is the temperature gauge even moving?
Other than emotions and assumptions, what is telling you it's overheating?
What ECU do you even have?
  • Like 1
Running a complete link setup now with a tune… reason I think it’s heat related as it only does the cut off after 30 mins of driving in the heat and didn’t do it at night time when the temp came down. Otherwise will look at the data and possible change the over boost max boost settings on the ecu. But yeah your right little guessing…
4 hours ago, Milkmun said:
What actual temperature is it hitting?
This is the issue as the stock gauge I have heard won’t really read correctly and if it moves up it’s already too late. Mine moved up a little - I would say just past middle. Hence my motor wasn’t cutting off below 6500 max boost, I think if the temp was really high it wouldn’t go pass 3000 … that’s why I wanted to run a separate more efficient water guage and sensor to check readings closer - if anyone else is running them? And add a boost gauge while I’m at it.
14 hours ago, Sleepergm said:
Hi all,
thanks
Make sure the radiator fan shroud is on and in good condition. Make sure all the radiator guides are in place. Make sure your intercooler isn't restricting too much airflow to the radiator. Change your coolant out for a 30/70 glycol/water mixture instead of the normal factory recommended 50/50. Make sure your radiator is halfway decent, so not Mishimoto. Make sure your fan clutch is functioning properly. If you have the factory oil/coolant heat exchanger a larger oil cooler or better ducting can help take the load off the cooling system.
If your tune pulls out way too much timing to achieve the power figures that it does and the pressure peak is happening well after TDC turn down the boost. Less thermal efficiency means more of that heat is going into your coolant and engine oil instead of the wheels. E85 would likely help a lot in this situation as it naturally has more water dissolved in it and the combustion of alcohol releases a lot more water than gasoline.
I would also recommend doing some temperature logging of various fluid temperatures. Rear differential, transmission, transfer case, front differential, power steering fluid. Gear oil shouldn't exceed ~140C. If it is getting too close for comfort you might need to consider some method of cooling it off better. Keep in mind that these systems are kind of all interconnected. The oil pan holds the front diff for example and keeping the engine oil cool will help cool the front diff in turn.
  • Like 1
The first thing you need to do, is validate if you have a problem of overheating, or something else going on.
Do some data logs.
What is the whole spec of the car, and don't just say "bigger radiator", what brand, size, etc?
What FMIC, what's done to the motor?
6 hours ago, GTSBoy said:
Yes, the fan shroud.
Yes still have that .. what to keep the stock parts and plastic bits relatively stock looking as I started off with a pristine vspec specimen. Will resell her in a couple years. Is this stroud restrictive?
Great info as usual. Thanks …
im already running a hks oil cooler. I will check my coolant mixture - that’s interesting.
I guess if the problem persists the next stage is to run datalogging but I will need to do this when the temperatures are crazy hot. Hong Kong is going thru a heat wave right now.
30/70 should be standard in any tropical climate. If it never drops below 0C this is an easy way of getting more performance out of the cooling system. Nissan explicitly recommends this. If you want to go even more extreme you can go 100% distilled water with redline water wetter. Change it frequently if you do this as I'm doubtful on the corrosion protection. Make sure the airflow into and out of the cooler is managed. Don't use excessively restrictive mesh on the intake or exhaust for the oil cooler. A friend of mine has tested this himself when installing a front mount intercooler on his car. Seal up any gaps in the ducting. You may want to find some way of fitting a larger oil cooler in the space that the HKS cooler currently uses but that core is already pretty close to what is practically possible. You can also try to fit a cooler in the space where the OEM diverter valves live but that's a bit challenging like the HPI kit. Or you can take the F80 M3 approach and put one laying flat under the radiator/intercooler/etc but you need to be extremely careful about not scraping the underside of the car. F80s are notorious for emptying their oil pans when someone takes a speed bump too aggressively or scraping on a curb.
Edited by joshuaho96
  • Thanks 1
Those setups of laying a cooler flat isn't just a case of lay the cooler flat.
There's a bunch of aero that goes into it too.
Its why some cars if you even take the plastic under tray off they can start having hot/cold issues.
Yes, in the case of the F80 it's basically such that air from the front of the car that would want to bypass the radiator/charge cooler/condenser stack is instead forced down through the oil cooler and then ducted out the bottom. It's definitely annoyingly complicated and not that simple. Power steering also suffers from similar problems, the factory "cooler" is just some fins attached to one of the hardlines running along the subframe and it's not really good enough to keep the fluid from boiling/out of the reservoir under track use.
8 minutes ago, r32-25t said:
I had been led to believe BMWs were out of the box race cars
The F80/G80 are pretty close, just don't bottom out/scrape on anything substantial because all that's protecting the oil cooler from puking 7 quarts out is a crappy piece of plastic they call a skid plate. Not unusual to take off the covers and discover that the whole cooler is bent and needs replacement.
3 hours ago, r32-25t said:
So you’re saying they’re plastic junk like every other car these days
Oh they definitely are plastic junk.
I'm also concerned at him giving advise to lay an oil cooler perfectly horizontal, without mentioning anyway of getting air flow through it, even though he recognises it's quite tricky and complicated.
The best advice for this thread, has been given, and it's not start working on things and changing them, it's work out from hard data if there's an actual problem, and what the setup presently is. If we don't know what the setup is, we can end up chasing our tails around and around and around.
  • Like 1
 Share
    • I don’t think it is ground. From factory it has 12v switched to one side of the ETS solenoid and the failsafe solenoid. Then the factory ets ecu has a pinout to send voltage to the otherside of the solenoids. I can see the ETS solenoid ranges from 0-3.3V to control the pressure to the transfer case.  Im just not sure what voltage goes to the failsafe.    I’m wanting to hardware these solenoids to avoid using the factory computer. I’ll link the factory R33 wiring here.
    • Oh, I wasn't expecting it to be available new. I was thinking to check whether it's shared across different Nissans. Amayama usually mentions if the part is used in other cars. Might be easier to find a wrecked Skyline, 350z or whatever if it is also used there. Have you talked to Jack Phillips JDM to see if they have anything? https://jpjdm.com/shop/index.php With them it's worth asking as they don't list everything they have.
    • Well....ground, obviously. A 12V solenoid only works when it has 12V on one terminal and the other side of the circuit (ie, ground) on the other terminal. They're just telling you to hotwire it. Of course, you should not do that without a fuse in the 12V supply. Protect the wire from the solenoid going short.
    • It's defo what happened. Not the exact same in each case. Remember, this is like the 8th time that BBS has been in "difficulties". Recaro, on the other hand.... we're only talking about the automotive aftermarket part of the company here. The business that makes aircraft seats, bus seats, military vehicle seats, etc etc, is not in trouble. I think the investment company is just being unemotional, purely profit/greed driven and culling BUs that are not making fat profit. The replica stuff won't be helping, because Recaro seats are unarguably too expensive to sell to anything other than a very small market segment.
