R32 Rb20det Starter Issues
Can we not just turn the boost down until you get the car tuned? -
Wheels fitted, tyres look good on them I really cannot go any bigger than the current set of PS5 215/45 17 tyres as I've got bugger all clearance from the unrolled guards in the rear, I was a little concerned when I first got them fitted, but I just got back from a hour drive, throwing it around some bumpy corners and looking for bumps in the hwy to try and bottom out the suspension as much as I could, with no rubbing at all....winning With the rear guards rolled it will easily fit a 225/45 17, and probably even a 235/40 17, but, it really doesn't need any more tyre, the 215's are sticking fine and a wider tyre for grip isn't needed for the street
Ok cheers. I'll get that tune asap then and probably even do an early oil change.
