R32 Rb20det Starter Issues
Newcastle and surrounding area owners, where do you have your car serviced?
I'll double check the model. I also got told though from my mechanic I can plug it out as well and I'll go back to wastegate pressure or something like that?
The yashio ones are FIA but I’ll take a look at velo and raceworks too as I have seen they do pink in some options. only issue is my bride Digo R seat does not have a spot for the 5th point belt to come through the base cushion. Don’t really want to change the seats just yet. How will would a 5point work with that style seat
By robbo_rb180 · Posted
Look at FIA rated/certified ones. 5/6 point, cam lock and good buckles. I've used sparco, MVP/Raceworks, velo. Also look at Hans specific 2 to 3 inch belts if using a Hans. Raceworks will do fancy colours too
