Camber arm hitting knuckle arm BNR32 GTR
I mean, kind of preaching to the converted here. Everybody here (mostly) has Dallied a skyline for many years and knows the ins and outs. You could have asked the question here instead of making a video and got detailed responses from people with years of experience. They are entirely perfect to daily, especially stock. That is what they were built for.
Hey all, The 34 GTT lunges violently if you touch the throttle at very low speeds (carpark), until you back off or throttle harder after the chassis has settled. I suspect the tune needs a little more work, but want to try some little haltech setting changes if possible to soften the hit when touching the throttle at walking pace. I suspect the remote mounted IAC (plaz top-half w/cable TB) may be partly ,or fully, to blame as the airspeed at that low rom and load could possibly be disturbed with a laggy remote IAC. The driveline has 1pce driveshaft and twin-plate clutch that "may" exaggerate the issue.... Does anyone have any thoughts, or have experienced this? What settings in the Haltech could soften the jerkiness? Say initial 0-2% throttle opening at less than 1200rpm..? Thanks in advance!
Possibly the headlight switch has shorted out Pull the switch and test the terminals
well all done was crazy how many screws i had to undo to get that plastic plate off. but replaced with 5w30 Edge and new filter went about 5.5lts of oil over the 5.3lt standard though i noticed abit of crusty coolant on my undertray looks like its come down from the overflow out that has no pipe? should it have a pipe? also could be just me but i noticed loud ticking now that maybe i just didnt notice before(not that i had my engine running with bonnet up much). anyone else notice this maybe after changing to 5w30 over 0w20 oil?
Pissed off the random Raceworks fitting on my car, was fitting when the new motor went on. Not sure what happened to the original Speedflow one before the motor went bang.
