If you saw something worth taking a photo/video of on the streets in Japan, then post it here (pretty please? 🥹)!
To get things rolling, an absolutely millimetre perfect restored 1st gen VW Golf on BBS RS with gold bolts and from what I could see, an immaculate interior. Was at an intersection and the lights turned green so only got one photo
  • Like 3
https://www.sau.com.au/forums/topic/485661-spotted-on-the-street/
Damn, thats gorgeous!
11 minutes ago, PranK said:
Dang. What would that be worth there?
Funny you should ask... 😁 $200K according to this for a 'practically new' one:
https://misha.tokyo/car/58
I'm not sure what I was expecting but I guess this doesn't seem *too* bad.
  • 1 month later...
This one isn't "on the street" per se, but it was on the street just prior to the photos being taken.....
Mitsuoka Nouera, based on a CL7 Honda Accord. It was in the carpark of the Hanshin Nishinomiya train station "Ebista" shopping mall. I'd say they are very rare compared to other Mitsuoka models.
On 20/09/2024 at 9:34 AM, PranK said:
Yikes. That might do well in the Automotive Abominations thread!
Indeed.
Mitsuoka always did their magic on various Nissan models, but because the Nouera was going to be in the medium sized sedan class, they decided not to try and modify the 2004 P12 Nissan Primera because it looked too modern combined with the 1940's styling. It would contrast way too much so they went with the more suitable CL7 Accord... 😆
A Dodge Challenger and two Chrysler 300Cs with straight pipes making lots of noise just over from the Ebisubashi (Ebisu bridge)
https://www.instagram.com/reel/DAQqr_iNnCB/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
Edited by Rezz
On 13/10/2024 at 4:12 PM, luke gtr said:
Here's the cars i took pics of when over there last October.
(If they load)
Some on the street, 2x nissan in showrooms.
I wonder if this guy is a F1  Paddock Club member and did laps at the Suzuka GP last year after the Porsche Cup sessions? Car looks exactly the same as what was on the circuit. It spun out at the hairpin and did a huge 180 deg burnout to get going again. Good to watch (and hear!)
This one's got me stumped. It's a Mercedes Benz TN/T1 310D high roof, but I can't find any mention in Japanese sources  about it as a OEM Mitsubishi model. Any more info?
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
