Hi all,
The lenses on my front bumper turn indicators are cracked. I've had limited luck looking up the part number, but the part is an Ichikoh 3323, except with clear lenses (not the stock amber). Is there some place to get replacement, clear lenses? Are these from the Nissan parts bin, but maybe a different model? It looks like the Silvia units are close, but I'm not convinced they'll work. Any help would be appreciated.
-Kip
Edited by Kip
https://www.sau.com.au/forums/topic/485664-replacement-turn-indicators/
I don't have a Stagea but what I've found after a quick search is that the S14 Silvia "winkers" (as they call them in Japan) do indeed fit the 260RS Autech, but are a little more 'curved' in appearance. I'm sure you've seen this already but it seems that the S14 winkers are easier to get. There were companies like KT Project who made aftermarket clear winkers for the Stagea (pre-facelift) but they are gone now and pop up on Yahoo auctions from time to time.
Maybe someone else has the genuine ones? I couldn't come up with anything at the moment for sale.
  • Like 3
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
