Just curious anyone running anti lag tune on a bi turbo setup… guessing the benefits aren’t too rewarding … to be honest I do the like the shooting flames on revving though … I know it might not be good for the longevity but i do think I would enjoy the flame shooting in front of crowds. Take it however u would like, 😭
https://www.sau.com.au/forums/topic/485665-anti-lag-on-bi-turbo-setup/
Engines are expensive. You already mentioned having thermal management issues with your car, anti-lag dramatically raises EGTs and can easily damage a cylinder head. If your goal is actually to improve transient response I recommend VCAM. DBW can also help here. Instead of a simple mapping of accelerator pedal position to throttle opening instead you interpret the accelerator pedal as a certain torque/power request and the throttle will open more or less to achieve that. So if your desired acceleration requires getting 0.5 bar of boost the throttle will silently go wide open to spool the turbos, then as it gets to that target intake manifold pressure it will adjust the throttle back to the steady state target. Another trick you can play is detecting when a shift is happening using a strain gauge and clutch switch for example and rather than snap the throttle shut when the accelerator pedal closes you cut fuel injection and hang the throttle open to keep the turbo from slowing down. This is a pretty complicated trick to play though as if it got stuck in that logic you would have engine runaway and you want to make sure the engine RPMs actually fall at a reasonable rate instead of rev hanging badly.
  • Like 1
Sounds like all you want is a button on your CAN dash pad that is for 2-step / anti lag launch.
Hold the button down, rev limit gets set to whatever you want, say 5000 rpm. Then mass timing is pulled and a heap of fuel is dumped in for fun times. Want more bangs and flames, pull more timing or add more fuel or both lol.
Obviously the more you use the fun button, the shorter the life of the entire hot side of your motor. So valves, turbo, cat, any sensors in the exhaust, etc etc.
Well, if you are using it for its intended purpose it is very rewarding. If you are at the drags and want to launch on full boost, how else are you going to do that?
  • Like 1
4 hours ago, GTSBoy said:
I thought you were concerned about being arse raped by the HK police?
Hahah yeah but a man got to do what a man wants to do. Won’t be using it infront of the 5O anyway. My car is illegal as is with the mods.
Thanks for the info… guessing less rewarding for my hks ss turbo setup. Might just be more beneficial for a single turbo. I’m just concerned it will hurt my engine long run which would be very expensive.
Well not really, 2-step doesn't care if you have 1 or 2 turbos. It will function the same either way, it will let you build boost while stationary.
You should be concerned, it will 100% hurt your engine in the long run. But you want to shoot flames and have crazy pops/bangs yeah? lol.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
