45 minutes ago, hardsteppa said:
But also no. Because why would you install a 90's-tech manual boost controller when you can get a reasonable electronic one cheap nowdays.
I wasn't even going to try that argument. I mean, the argument is 100% valid, and I would take an old Profec over a manual controller every single day, but.....too many words to type.
  • Like 1
8 hours ago, JC71 said:
can one remove the stock wiring, bracket and "dual stage (5-7) solenoid" control assembly, if installing an aftermarket (turbosmart) manual boost control?
Sure. Make sure to put some dielectric grease on the terminals and cap it in case future you wants to run electronic boost control again.
indeed, I hear you, but, fortunately I have the time right now to type some sh!te. You can now get a cheap elctr boost controller that will do boost by throttle position, boost by engine temp, overboost protection, boost by rpm, boost by your girlfriend's menstrual cycle, boost by the lunar tides, boost by the Gregorian calendar, the whole lot. All for not much.
Posted (edited)
where is the best location to connect the pressure source line to the manual boost controller???? my rb25det neo has a front mount intercooler, and therefor the stock fitting (like in attached 1st pic, white arrow) on the upper intake pipe is not there. I only see one other smaller hose fittings on the stock intake cross over pipe before the throttle body, just below the recirculation or "BOV" valve.  currently has the blk and red little "filter" in this line. (2nd pic whit arrow)  Able to put in a T and use this one? I have also seen some pics where people appear to have T into the hose going to the recirculation valve nipple??. please advise. thanks.
Edited by JC71
Posted (edited)
I looked it over last evening and took a few pics. trying to simplify as much as possible. cap or remove whatever is not needed and add two lines, to and from the aftermarket manual boost controller.
there is a nipple on the aluminum/cast elbow between the turbo and intake filter,
another on the steel "hook" pipe in front of that, that looks to be connected to the rubber pipe between the turbo elbow and intake filter as well.
the one on the wastegate, and the two currently to stock solenoid valve
Edited by JC71
Posted (edited)
not sure what you are calling a hot pipe...
but your saying to eliminate all hoses here, cap all nipples.
block line off the aluminum elbow off the front/top of turbo, and block the one off the steel hook pipe in front and above that, remove solenoid, and both those lines.
drill and add nipple to this intercooler pipe? in pic at red arrow, (as similar to where stock had one) and run a line for "pressure source" to the manual controller from there, then the out the controller to the wastegate?
Edited by JC71
Posted (edited)
I would assume the hot pipe would be referring to the intercooler piping that comes right from the turbo headed towards  the intercooler, and the cold side would the be the pipe after the intercooler headed towards the intake /throttle body?
if this is the case, do I want it as close as possible to the turbo or furthest from, to get the most accurate reading? and would the factory fitting on the turbo elbow be the perfect location for the pressure line for the boost controller??
Edited by JC71
Yes.
Yes. On an R32, for example, the nipple is actually connected onto the compressor housing. Right on the front. There is probably a pad on the front of yours that could have been drilled and tapped, but likely wasn't, because they stopped putting it there, for some reason.
If there's a fitting on that elbow, then yes. Can't see it because the photo is tiny and the arrow is in the way. But yes.
Posted (edited)
wow!!!, what a difference a manual boost controller makes. simplified everything, and cleaned up the engine bay even more. It's a good steady boost now, I set it around 8 for now, no dual stage crap, seem to improved spool up delay, sounds better, and I don't have to push rpms so high to get power and torque. A few other tweaks and I think this thing will be ready to rock.
The turbo air movement rushing sound is still there and loud as ever, even though I found no play in the carriage shaft, I am convinced its from the turbo itself, as has over 100K miles and its the original stock turbo.  I plan on replacing the turbo itself over this winter as all the other turbo system components are correct.  I found and acquired a new old stock RB25DET NEO Nissan OP6 turbo 45V assembly, which I will swap out both nylon and ceramic wheels with steel ones.
thanks to all who helped!
Edited by JC71
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
