Trying to install the positive long positive battery cable and protectors from a factory GT-R into my GT-T (i have the cable and protectors and clips).  I have googled and watched YouTube videos and am unable to locate the mounting points and exact routing of the BNR34 positive battery cable that goes from the trunk battery to the front fuse box in the engine bay.  The best photo i have have found is attached which shows it running up the outer side of the driver side subframe and underneath into the engine bay.  Does anyone have any photos or routing for the rear?  There is a grommet that that it goes through on the passenger side behind the battery above the fuel tank, and i believe it gets mounts over the hump in the subframe towards the passenger side.  I'm hoping anyone who has a R33 or R34 with a factory trunk battery can post some photos of the routing of the cable.  Appreciate the help!
I can take some better pictures when I get around to pulling the transmission on my R33 but this will probably give you some idea of where it's routed.
Thanks, i have those photos and the R34 version.  It's where the wire crosses from the passenger side to the drivers side that I'm unsure about.  I'm pretty sure it follows/mounts to the arch of the rear subframe, but i have been unable to confirm.  Photos would be great!!  Thanks
If by this you mean the stiffening rib in the floopan, then probably yes. There would be no way that it would be attached to the actual subframe. That would be silly.
Possibly, like i said, i just don't know.  I'm only guessing by the shape of the cable.  Stiffening rib would make more sense though.
IMG_7438.HEICIMG_7436.HEICIMG_7435.HEIC
Not sure why these images refuse to be uploaded in jpeg format but that's the way it goes. Basically runs just to the right of the brake lines, up and around the top side of the front of the fuel tank, makes a turn and heads back at the corner, then the last bit goes straight up near the wheel well into the trunk.
They have some strange meta data. I was able to repair them on my Mac.
  • 4 weeks later...
  • 2 months later...
Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT.
I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors?
How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis?
Any help you can provide would greatly appreciated.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
