How does the air regulator works ?
Will a GTR diff fit into a GTST? will it bolt in directly. Can I swap my current GTST stubs and shafts onto the GTR Diff? sorry newbie when it comes to the diff
By MrCodZilla · Posted
Both Headlights Installed.mp4 Forgot 2 more videos, Fixed the Misfire on cylinder 3 and both COB headlights installed from Japan Fixed Misrefire.mp4 -
just a short update with pics for those who are interested. - turbos both blown (wheels are stiff/ wont rotate anymore) - oilpump broken - crankshaft wear on front (dont know if this is repairable) - one bearing is nearly dead, all the other seems good with slight wear (will replace all of them regardless) - other stuff i dont know. need expert for review whats repairable and what is not (surely Pistons will all be replaced also)
Update on my build, hopefully all the videos are ordered correctly. Attempt to Start - First Crank and Rough Idle - Turned off .mp4 Attempt to Start - First Crank and Rough Idle - Turned off V2.mp4 Attempt to Start - First Crank and Rough Idle - Turned off V3.mp4 Attempt to Start - First Crank and Rough Idle - Turned off V4.mp4 Idle and decent RPM and watch it drop and build.mp4 Idle and walkaround.mp4 Started and letting Idle.mp4 Little Rev and turbo spool with backfire.mp4 Little rev and turbo spool.mp4 First Start - Outside PoV.mp4 Testing Indicator.mp4 Wired up Heated Mirror and Indicator.mp4 -
Thank you Colin for the response. It actually does help as there isn't information what so ever with using EcuTek functions with the AutoStrada Kit, so its very scarce. Honestly, I don't even want the ability for cruise control, I literally only want the ability to switch maps + AntiLag from EcuTek. Based on what your saying, every ECU is optioned from factory its either just disabled and have to have it enabled, however that enabled function won't even work if there are not switches to utilize it. So then the Can-bus is just used to capture information such as the speed/set speed, am In the right direction to where I should be able to just plug in the controller with the cruise control switch and have it enabled in the ECU, then EcuTek would be able to do the rest? Don't get me wrong, it would be a "nice to have" feature having Cruise Control, but I would be more in favor with map switching and Anti-Lag, I do have EcuConnect OBDII app can should have the function there to switch maps.
