It's not connected to the fuel pump. It's connected to the same 12V supply as the fuel pump, so that it is only heated when the fuel pump is active (ie, mostly when the engine is running).
In case that wasn't clear, it is heated. Electrically. When it is cold, it is open and flows air. When it is warmed up, it closes, and does not flow air. Hence, it is a cold engine idle up.
  • Like 1
  • Thanks 1
55 minutes ago, wardiz said:
Depending on the coolant temperature and on the target engine RPM it closes and opens quickly to achieve the required target. It's a kind of duty cycle.
Intake air regulator is not the same as AAC valve. Intake air regulator is only there to raise the idle airflow at cold start. After a certain amount of engine runtime the shutter should fully close and all idle airflow goes through the AAC valve instead.
  • Like 2
Unpopular opinion, rip all that junk out (AAC, IACV, TB, Cable throttle, etc.) throw it all into the recycling bin.
Go DBW throttle.
Superb idle control, throttle response, cruise control, and all the fun stuff like throttle blips, rev matching etc.
8 hours ago, wardiz said:
I didn't know that about the air regulator thank for the info.
According to the pinout it looks like it's not controled by the ECU, is it ?
As others have said it is technically controlled in the sense that the ECU turns on the fuel pump which also turns this thing on. Other than that there is no real control. So you could in theory do something stupid like repeatedly prime the pump without starting the engine and that would cause the shutter to close and the cold start idle to be too low. I believe the NEO series might have a thermostat controlled cold start valve instead but I've never been able to disassemble the idle valve.
Go DBW throttle.
Not wrong, but the actual physical intake air regulator + idle valve isn't the issue for packaging in an RB26 so much as the giant common vacuum chamber hanging out under the intake plenum which is still needed for the brake booster + BOV vacuum lines if you're keeping it mostly stock. I've kind of made my peace with it.
Neo has a combined IACV and AAC on the back end of the plenum. Coolant heated (it's got a bleed point on it). No electrical heat. Works very nicely when it is clean.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
