I don't know, but I can confirm the paint code shown on your build plate is the external panels; on all R chassis the internal panels including engine bay are similar but not the same as the external paint.
You will probably have to get the paint shop to just match what is there as best they can
  • Like 2
I had this with my s2 R33. I found a grey paint tone called Double Stack (NZ Resene colour), it's very much a battleship grey, looks good but still does not match the original. The factory grey has a blue accent in the tint. A grey tone called Quarter Friar grey might get it; https://archipro.co.nz/product/resene-quarter-grey-friars-resene
With hindsight an experience painter could nail it easy, I had fun, almost, trying. There are a lot greys.
  • Like 1
Would u happen to have a pic of the area u painted with the “double stack”
if it’s close enough I’ll just get some of that
Here it is, shot this morning at work, road worn, dirty & working for a living for 6 years now. No rust there, just dirt and in places it's stuck to the Lanocote I spray around the seam sealer where water deluge drainage is a lot.
Sort of industrial tone. Don't be fooled by thinking you can get any old grey paint in a can to match. I'm still picking away through a box full of them I collected back then trying to find the right one, good for other home projects.
  • Like 1
Cheers, It must be close enough coz I can’t even tell where u painted. Did u do the whole top of the strut tower or just a patch somewhere?
On 7/27/2024 at 1:16 AM, Milkmun said:
340k km? Wow 😮
Reading about 424 000 km now. Long live the 20E. It was like an abused dog when I got it  @ 230 000 km, they'd killed the auto and half shafts, including diff. It is the same motor.
Edited by czeno
  • Thanks 1
I painted all the top area both sides and down as low as I could get, up to firewall which is original, under the right lighting you can see the mismatch, it's got a hint of blue as I said before. I had rust in same places you are dealing with.
  • Like 2
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
