Well was troubleshooting what sounded like an rpm limit being set on the car just as it was building boost and noticed my wastegate is open at idle.
As I was using a prybar to put some pressure on the rod to see if I had any binding doesn’t it slip and end up hitting my fuel injector resistor mounted on the passenger side firewall HARD. Checked all my wires and everything’s good but now the car won’t start 🙃
Upon initial turn of the key it sounds like it’s about to start for a split second before it just cranks. Strong smell of fuel, car has spark.
Now I’m assuming my smacking of the resistor messed something up internally and the injectors are dumping a ton of fuel (plugs are wet and even QuickStart/ether won’t do anything after cranking a few times it’s so flooded)
This make sense in other people’s minds before I drop the money on a new resistor? Car went from idling mint to not starting at all after that one slip
https://www.sau.com.au/forums/topic/485683-r32-fuel-injector-resistor/
Thanks everyone, it does in fact only have 2 wires so it’s the fuel pump resistor (still new to skylines and RBs as you can all tell haha) my symptoms still make sense?
im getting fuel pressure at the regulator (has an aeromotive with a gauge) and can hear the pump running
Car wont idle without the resistor in place. You can also bypass it. If you need one meanwhile, message me. Cheers.
Thanks! Tried to send you a message but I must be too new still, if you can send me one I’ll probably take that resistor off your hands
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
