Hi everyone,
I want to start organise buying the parts to do a transmission fluid, gasket and filter*(strainer) change on my R34 GTT Series 2. I've got the part numbers from a tutorial on YouTube (shoutout to The Build Room) and I've found a Filter Kit on Kudos Motorsport - https://www.kudosmotorsports.com/catalog/automatic-transmission-filter-4spd-suit-nissan-skyline-250gt-stagea-wc34-series-p-1609.html
I'm not sure if their image is for reference only, but the filter on that image only has 4 bolts whereas the actual one off the video has about 12.  So I want to make sure I don't buy some wrong part 馃檲
Has anyone here bought the filter kit off Kudos for their R34?
Thanks in advance
https://www.sau.com.au/forums/topic/485695-r34-auto-correct-filter/
4 hours ago, DraftySquash said:
Hi everyone,
Thanks in advance
Oil pan gasket is 31397-41X04. Strainer assembly is 31728-4AX00. You can look at this yourself: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er34/3945-rb25det/trans/317 and https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er34/3945-rb25det/trans/311
Checking online the actual picture of the OEM filter looks like this:
Yup @joshuaho96
those are the same part numbers I got as well but this kit from Kudos comes up when I鈥檓 searching.
I鈥檝e emailed them asking if the pic is accurate and hopefully they say it鈥檚 for reference only.
worst case, I鈥檒l get it off Amayama. But I鈥檇 prefer Kudos so it doesn鈥檛 take almost a month to come 馃槀
I'd be happy to trust Kudos, they sent me an incorrect connector a while back and when I realised they sent the correct one immediately (and told me to keep the other).
Yes I'd prefer they didn't make a mistake in the first place, but in my experience every business does some time or other and it is how they make it right that matters
  • Like 1
Just placed the order with Kudos today and THEN emailed the sales team again and they confirmed the filter pictured below is what I鈥檒l get.
So now looking forward to a fluid change and buying about 12-16L of Castrol Transmax Z 馃槀馃槀
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
