Hello,
I am in the middle of installing the attesa ets pro in my r33 gtr non vspec and am confused with how the safety solenoid should be wired up. 12V switched to one side? And then ground or 2V to the other?
Has anyone installed the ets pro to an attesa system with the safety solenoid? I can not find any information on how the safety solenoid should be wired up.
cheers
https://www.sau.com.au/forums/topic/485701-attesa-ets-pro-install-on-r33-gtr/
This is the section I am confused about. 12V to one side of the safety solenoid, but what to the other side?
All the other wiring I have no issues with.
Instructions can be found https://www.full-race.com/ets-pro-nissan-skyline-gt-r-center-differential-attesa-torque-split-controller-for-r32-r33-r34
And
https://www.full-race.com/resources/installation-instructions/ets-pro-universal-install-guide
Well....ground, obviously. A 12V solenoid only works when it has 12V on one terminal and the other side of the circuit (ie, ground) on the other terminal.
They're just telling you to hotwire it.
Of course, you should not do that without a fuse in the 12V supply. Protect the wire from the solenoid going short.
I don’t think it is ground. From factory it has 12v switched to one side of the ETS solenoid and the failsafe solenoid. Then the factory ets ecu has a pinout to send voltage to the otherside of the solenoids. I can see the ETS solenoid ranges from 0-3.3V to control the pressure to the transfer case.
Im just not sure what voltage goes to the failsafe.
I’m wanting to hardware these solenoids to avoid using the factory computer.
I’ll link the factory R33 wiring here.
Well, it has to be.
Yes, and, they are saying
"This failsafe must be disabled" (My emphasis).
And they are saying exactly how to do that....
"Giving the failsafe a switched +12V constant signal will keep the solenoid closed/disabled".
I interpret that to mean that "any time the car is running, you want 12V permanently on the solenoid". Ie, power it to close it when the car is running. Have the power switched off when the car is not running.
Edited by GTSBoy
Thanks for trying to help me mate. I tried it tonight with the failsafe solenoid with 12V IGN on one side and ground on the other side. No 4wd. Just spinning the rear. Even when setting the controller to manual mode and full locked 4wd.
I might try keep all the factory wiring in place and just have the FullRace system control the ETS solenoid. However, I would much prefer to hardwire all the system so that I can ditch the Attesa ECU.
I can’t tell if the failsafe solenoid is opening or closing when powering it.
I put the factory system back in for a sanity check that the system still works. It does, factory 4wd works.
Was going to try wiring the new system to the ETS solenoid and leaving all the factory relays ecu in place. But realised the stock attesa computer shuts off all the relays when the ETS solenoid is disconnected. I could try get a resistor to be a dummy load over the factory ets solenoid.
If only there was a spec sheet for the solenoids so I could understand how they work.
Solenoid valves are just a coil of wire wrapped around a movable iron core. Put the required volts onto it and the wire creates a magnetic field that makes the iron core move. The moving iron core forces the valve to either open or close (depending on whether it is a normally open or normally closed valve). NO valves are closed by powering them. NC valves are opened by powering them.
The failsafe valve is NO and is closed when powered.
You should feel it click when it changes state from on to off or vice versa.
I have confirmed the failsafe solenoid clicks with 12V on one side and ground on the other. Still no 4wd though.
Now I guess the only part left is the ETS solenoid. I don’t hear this click when in manual mode and adjusting the dial. I’m going to reach out to the manufacturer and ask what the correct outputs should be from the black and white solenoid wires.
Perhaps there is a fault with the unit.
Or if anyone has a unit and they could tell me what voltages come from the black and white wires when not connected to anything. That would be appreciated
Yes the ETS controller light is on, in auto mode it is a bit dim, in manual mode it adjusts brightness with the dial. The wiring for the controller is 12V ign to the red wire, ground to green wire, tps to blue wire, solenoid wires to black and white and the handbrake wire, brown, I have not connected to anything (you would ground this for rwd). Please correct me if I have that wrong.
The pump I have connected to a relay like such. I hear the pump power on and stop when at pressure. I don’t think I have this incorrect?image.thumb.png.14abaa68517d83e51d1ecd120ab7579b.png
  • 4 months later...
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
