I noticed my oil on my rb25 stays gold for about 3,500km roughly. Then goes light brown after that. Probably around 4,500 mark it goes dark brown (this is me driving normally with no / minimal pulls as i blow black smoke when i boost) (when I drain the oil it's black at 5,000 no metal shavings though in the filter or oil)
I noticed now that it's been under 3,000km and it's dark brown. I think it's because I've been doing a few pulls more than usual (pulls means, in first gear going up to 5000-7000 rpm)
My oil doesn't smell like fuel at all, and isn't causing me any issues but I don't want to get bearing wear (yes I'll be getting my car tuned soon to)
I don't know if it's just me or if my oil is a bit thinner (I'm comparing brand new oil to oil that has roughly 2,500km from memory so might not be a good comparision.
Edited by silviaz
1 hour ago, Murray_Calavera said:
Can we not just turn the boost down until you get the car tuned?
I'm not sure how to do it, I'd rather leave it to the tuner, the thing is I think it probably technically runs rich when I drive normally as well I just don't blow smoke (unless I do a hot start a bit of black smoke leaves the exhaust, but never have smoke on cold start)
Edited by silviaz
2 hours ago, Murray_Calavera said:
What boost controller/ECU are you using?
I'll double check the model. I also got told though from my mechanic I can plug it out as well and I'll go back to wastegate pressure or something like that?
Edited by silviaz
If you disconnect the line going to your wastegate, you'll run spring pressure.
You shouldn't be doing anything but driving the car to the tuner, off boost.
Doing this could well be within the boundries of comparing:
"Does my oil go black faster"
and
"Do the pistons usually stay inside the engine?"
  • Like 3
  • Haha 1
Unplugging the wastegate solenoid should be wastegate pressure. Do not unplug the vacuum lines, leaving it at atmosphere will cause a big overboost event.
and
"Why do my pistons have little dimples in them kind of like a golf ball?"
"Why does my pistons have a huge hole in it"
"Why did my valves burn out in my head"
"Why did my turbo get cooked?"
  • Haha 1
Not the wastegate solenoid, he was saying the actual boost controller. The vacuum line going to the boost controller he said just to tie that up so I don't have a boost leak.
And that would be wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong wrong
  • Like 1
  • Haha 1
Alright, I believe you 😂 Many my original mechanic has gotten a lot of things wrong lol.
Edited by silviaz
This is a car that should not be being driven around. Also, an untuned car running rich due to mods is... never a thing. Also, driving an untuned car long enough that you're inspecting the oil is all sorts of wrong.
You are speedrunning the Car-Darwin awards here dude.
I get it, you want to have fun and be cool in shiny toy.
All valid. It's tuned but a poor tune lol. I'm only inspecting the oil because I did more pulls that usual as mentioned. If I don't do any pulls it stays clean for a decent amount of time, but I will get it fixed! It's just taking forever because everyone is busy.
Edited by silviaz
and this
Just don't add up for me.
What is the go with the tuning on your car, who tuned it? Was it put on a dyno?
Also, I'm still waiting to find out what type of ECU and boost controller you have lol.
3 hours ago, Murray_Calavera said:
and this
That's the thing I have no idea who tuned it and not sure if it was dynoed, and is why I need to get it tuned because I don't have paperwork. In regards to the ecu, I checked that a while back and I couldn't find it lol, it is aftermarket though my last mechanic told me. Anyhow I'll just leave it for the tuner.
Ah ok. It would be a lot more accurate to simply say, the car has not been tuned.
Blowing black smoke on boost is so crazy far from any state of 'tune' that I would not even call it poorly tuned.
Do you know where the ECU lives? It takes about 10 seconds to access the ECU and we could solve this mystery.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
