14 minutes ago, Murray_Calavera said:
Ah ok. It would be a lot more accurate to simply say, the car has not been tuned.
Blowing black smoke on boost is so crazy far from any state of 'tune' that I would not even call it poorly tuned.
Do you know where the ECU lives? It takes about 10 seconds to access the ECU and we could solve this mystery.
I'm just relaying what my mechanic told me. In my other post i talked about sonething similiar but some mechanics said to me that black smoke "can" be normal. But I'm out of my depth here.
Ecu is usually under the driver footwell? Or ive seen it sometimes on passenger footwells. Couldn't see it either.
If it hasn't been tuned, is it even possible for a car to run well (meaning it feels normal when driving, not thinking about A/F ratios and such) if it hasn't been tuned on a aftermarket ecu?
Either way needs a tune, I'll leave it to the professionals.
17 minutes ago, silviaz said:
passenger footwells
Yep, see attached
Yep. For example, you buy a Haltech ECU and upload the Haltech base map, the car will start and feel ok while driving however will have had 0 tuning done (provided the car is essentially stock, the base map will line up).
If you get a few seconds spare, please remove the passenger kick panel and solve this mystery for me lol.
  • Like 1
9 minutes ago, Murray_Calavera said:
Yep, see attached
Will do.
  • Like 1
14 hours ago, Murray_Calavera said:
Yep, see attached
To add to this.
Apart from some cranky cold starts, the tune that was on my ECU years ago for a relatively stock RB25, was happy to run and boost hard my RB30DET, with a TD07S on it.
It was very out of tune, but would run and drive "like normal". Except AFRs and timing weren't right.
  • Like 1
On 08/08/2024 at 2:58 PM, silviaz said:
I noticed my oil on my rb25 stays gold for about 3,500km roughly. Then goes light brown after that. Probably around 4,500 mark it goes dark brown (this is me driving normally with no / minimal pulls as i blow black smoke when i boost) (when I drain the oil it's black at 5,000 no metal shavings though in the filter or oil)
I noticed now that it's been under 3,000km and it's dark brown. I think it's because I've been doing a few pulls more than usual (pulls means, in first gear going up to 5000-7000 rpm)
My oil doesn't smell like fuel at all, and isn't causing me any issues but I don't want to get bearing wear (yes I'll be getting my car tuned soon to)
I don't know if it's just me or if my oil is a bit thinner (I'm comparing brand new oil to oil that has roughly 2,500km from memory so might not be a good comparision.
haha. I change mine every 1500-2000ks :D
4 hours ago, MBS206 said:
To add to this.
When you say timing wasn't right are you referring to the timing belt being a tooth off? I think my AFR's are f**ked but will find out soon.
No, he was saying that the ignition timing (which is what people mean when talking about "timing" wrt a tune) was not correct. Meaning that for any given load cell it could have been too retarded (and thus giving away power) or too advanced (and thus being close to or beyond the point of causing knock, and thus dangerous, and thus silly to drive around while using the engine in such a away as to access that load site).
We know your AFRs are f**ked. You're the one who told us it is blowing black smoke.
  • Like 1
The message here essentially is, your fuel mixture and ignition timing can be crazy far away from being optimal however the car feels fine to drive. He isn't talking about the physical timing belt when talking about timing not being correct.
  • Like 2
No, the tune was f**ked.
Much like your tune is.
It could end catastrophically for your engine. Either exploding engine, decimated bearings, or just burning the internals of the engine up.
STOP DRIVING THE CAR AND GET IT TUNED / LOOKED AT BY SOMEONE WHO KNOWS WHAT THEY'RE DOING!
  • Like 1
Ah right. I guess the CAS is also related to that?
Ah ok, makes sense.
I will.
No, on the basis that the CAS shouldn't be f**ked with, and if it is, it should be set back to the correct base timing with a timing light immediately.
  • Like 1
No.
The tune is f**ked. The numbers you put in the computer, aren't right.
If you keep driving the car, then it seems you want to take even longer, and spend even more money fixing a broken motor.
  • Like 1
3 hours ago, Alex001 said:
how come someone says, this isn’t a car that should be out on the road right now.
Like the others mentioned, you could do more damage because you're driving a car that isn't running right. It's like lifting at the gym when you've already injured yourself. You're just going to injure yourself more if you keep going, instead you should fix the issue (heal the muscle) before continuing.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
