Desean Strickland Posted August 8, 2024 Share Posted August 8, 2024 Hey guys, installing the gearbox front cover on an r33 gtst gearbox and just want to clarify a few things - what’s the torque spec for the front cover bolts? - should I put moly grease on the front main seal / the area behind the seal or just leave it dry - does the front main bearings behind the cover need grease smeared on before re installing the cover? (my understanding is it gets lubricated by the gearbox oil) cheers Link to comment https://www.sau.com.au/forums/topic/485725-r33-gearbox-front-seal-install-need-help/ Share on other sites More sharing options...
Duncan Posted August 10, 2024 Share Posted August 10, 2024 Per 32 GTR service manual (same gearbox) torque spec is 16-21nm (not shown in the chassis section but SD-11 covers it Nissan sometimes provide grease on the seal, if not I would put a light run of general grease (not moly) on it before placing the front cover (no seal likes being totally dry). And yes, everything inside is lubricated with gearbox oil, so the front bearing does not need to be greased. 1 Link to comment https://www.sau.com.au/forums/topic/485725-r33-gearbox-front-seal-install-need-help/#findComment-7992070 Share on other sites More sharing options...
Desean Strickland Posted August 11, 2024 Author Share Posted August 11, 2024 3 hours ago, Duncan said: Per 32 GTR service manual (same gearbox) torque spec is 16-21nm (not shown in the chassis section but SD-11 covers it Nissan sometimes provide grease on the seal, if not I would put a light run of general grease (not moly) on it before placing the front cover (no seal likes being totally dry). And yes, everything inside is lubricated with gearbox oil, so the front bearing does not need to be greased. Sweet thanks I used moly grease for the input shaft, is that fine? Or should I be using a different grease? also where did u get your service manual? I wana get one for the r33 gtst so I can stop asking every question I have on here lmao Link to comment https://www.sau.com.au/forums/topic/485725-r33-gearbox-front-seal-install-need-help/#findComment-7992078 Share on other sites More sharing options...
