Morning :)
little intro to the build r32 rb25 with a gtx3582 haltech platinum pro, 1000cc injectors 460 walbro fuel pump “maybe larger” with new lines and relay setup, new fuel lines an a FPR 1200. Made 350kw and Have had the car back now for a couple weeks haven’t had any real issue but this Sunday I got my first issue…. I generally fill up E85 at astron yagoona and with a quarter tank and on the way to a cars and coffee I stopped off at minto and put a full tank in it.
after about 10 mins of driving and letting it all settle in the car started to misfire and splutter? nothing consistent but noticeable? on the way back spent about an hour on the free way at 110km/h cruising at about 3000rpm and this is where the car started to splutter intermittently and wouldn’t give me any boost if I dropped to 3rd gear would stop and let me have boost then start again when I would consistently cruise at 3000rpm this is where progressively the splutter would get more consistent.
im about to check the fuel but the e85 at minto has always been consistent, I have aftermarket r35 coils and have pulled them apart and they look good to go and injectors sound to be doing there job?
At idle I don’t have any issues when i let it idle for a while and gave it a few solid revs and nothing? When I got off the motor way and was driving city speeds/ traffic “50km/h” no splutter?
Could it be a:
fuel issue?
coil issue?
tune issue?
will go for another drive to see if it starts up again and see.
any helps appreciated!!!!
Edited by 32pwwr
https://www.sau.com.au/forums/topic/485732-rb25-splutter/
3 hours ago, Murray_Calavera said:
Can you go for a drive, log all the channels and post the data up?
That would be too easy for diagnosing. It's more fun to play throwing darts aimlessly...
I vote change the O2 sensor. Reason? None, just a random dart thrown.
  • Like 1
https://www.sau.com.au/forums/topic/485732-rb25-splutter/#findComment-7992133
Love it haha, tuner came around and checked he said the timing was out and finds the Ross trigger kits to be a bit touch and go… back to his shop Thursday to fully diagnose but he thinks timing is the cause as we checked fuel pump, fuel filter, injectors, ignition and all came back good….
was very weird tho as only happened under sustained load cruising on the m7 at a sustained rpm and speed it would start sputtering felt like anti lag as when I put my foot down it would sputter or break up and not give me any boost then pull like a freight train when it gave me boost and was all at once
Edited by 32pwwr
https://www.sau.com.au/forums/topic/485732-rb25-splutter/#findComment-7992144
I would be suss that that behaviour was caused by the trigger kit. The trigger kit doesn't really care what the engine load is. It's just seeing moving metal next to sensors. It may fail to work at a particular engine speed, but wouldn't care if it was low load, medium load or high load. And it probably shouldn't change moment to moment. It's either good or bad, unless it is temperature dependent.
The symptoms you describe are typically fuel or spark delivery related.
https://www.sau.com.au/forums/topic/485732-rb25-splutter/#findComment-7992145
That’s what I was thinking, builds all under warranty so hopefully they figure it out quickly and I can post what the issue is
https://www.sau.com.au/forums/topic/485732-rb25-splutter/#findComment-7992147
I also would like to note that the r35 coils packs are aftermarket… and did note to him I feel that they are possibly breaking up under sustained load and heat as when I got home and let it idle had no issues and when I got off the freeway and started driving city speeds had no issues, so going to purchase hitachis.
first time really driving it for so long aswell as I’ve only had it for 1-2 weeks.
Edited by 32pwwr
https://www.sau.com.au/forums/topic/485732-rb25-splutter/#findComment-7992148
    • Back on topic for you for a post Will it be on pump or ethanol? 2025 Spec RB build: G30 660 .83 would be good  artec manifold turbosmart 45mm external gate 1000cc Injectors Kelford cams 264 and springs Pistons and rods for insurance Oil pump with billet gears Headdrain and all good oil mods Quality intercooler 3.5 inch dump pipe to decent exhaust Link plugin Ecu or what ever your tuning is comforatble with Bolt on Trigger Kit - Nzwiring kit is go to ARP Headstuds Quality headgasket quality fuel pump- a TI/walbro 525lph PWM would be the go Quality fuel reg Will be over $15K AUD Enjoy the noise of rb on gate at over 7400rpm. Start looking for gearbox conversions if your hard on the gear. Now I've been there and done that with rb powered street car (2007-2022) much prefer newer stuff. Anything 90's Japanese is not a great experience these days and highly over rated. My 2015 Brz with a heap of suspension mods is such a better car even with out the power of my old s chassis' even on track. If wanting to play light chassis and decent power for a  giggle a k swap 86/brz would be the go Check my old build for engine stuff I really need to pay attention to post 2016 BMW stuff but seem all very heavy 1600+kg
    • I mean, the 240i is not a Supra... make it drop a few hundred kg, have a sportscar chassis, clearance for wheels etc... Maybe I want a hardtop Z40i XDrive or something :p I do agree with you though and have long said the B58 Supra/240i/340i/440i is the new R Chassis/JDM90's turbo rocket for mod lovers to ... not always appreciative response lol. Doesn't make it not true though.
    • I will do the build myself but I will be paying for the tune because I don't know how much about that and would rather it be done right and by a professional
    • Will you build and tune it yourself or do you need to pay for labour?
    • Mechanically that's essentially what the M240i is, it's just not pretending it's not a BMW
