Got this r31 silhouette flood car to rebuild.
  • 25RBGT changed the title to Got this r31 silhouette flood car to rebuild.
Yeah mate 2022 at Lismore, I went right under! Luckily it was fresh flood waters and it has been sitting since after the owners cleaning interior.
the motor has compression and is turning over.
I couldn’t refuse the car for the price haha I’m in no rush, I already have a 34 and a patrol on the road. More of something to keep me busy and I really regretted selling my original 31 10 years ago.
Back to clean stock looking r31 silo with a little boost. That’s a long long way away.
Something to keep me busy for now
  • Like 3
Reminds me of my old 31 daily. The whiny diff and the replacement that was worth half the price of the car, the broken front seat, the peeling vinyl from the door trims, the mule kick from the series 3 auto box, the dodgy front ball joints and my dad crashing it into a Volvo.
Plus the many days spent at pick n payless grabbing anything good from other 31s and pintaras
  • Like 1
  • Haha 1
Yeah I remember these pick and Payless adventures with my fist couple 31’s 10+ years ago.Hardly anything left r31 in nsw now at wreckers.
RIP pick and Payless, I hear it never made it threw covid and they scrapped all the cars 😭
Found some cancer in the topical location for 31’s, do some emergency surgery over the next few days and see if it’s a show stopper for this silo.
New quarter panels I did a 1000km drive to get.
no rust under the chrome door surrounds just a hole lot of mud.
starting getting the fuel side sorted today
He managed to find me over on R31SkylineClub forum ~ he'll be headed up here whenever to pull the good fuel tank (and other bits and pieces) from my spare S2 pinny parts car... should help the project & keep costs down 😃
  • Like 1
Yeah mate, your help is just what I need to give this project a little bump along, and closer to putting the historic number plates on this silo. 👌😁
thank you
Little rust converter under the ass end some paint and fish oil and she’s ready for the new tank! Then we will get a ignition, thanks to the ever faithful r31 skyline club community most of all Solder.👏👌
 Share
    • Weird the Gktech one doesn't have the 3 holes and is only a 5min install if you have the standard front bar.
    • Honestly, as someone on the standard PS4 controller, should be relatively easy to get gold. Remember you have more grip than you think.
    • Fitted some Advan AD09s to try next. Likely slower than the CR-S but should work in the wet and last longer.   Off for alignment and the new plates worked a treat! I was finally able to hit both my drift and grip alignment targets with the same setup! Grip Front: Toe total -2mm(1mm out each side) Caster +7° Camber -3.8° Ackerman +15° Rear: Total toe +3mm (1.5mm in each side) Camber -1.5° —————————————- Drift as above but drop the front sway bar and change the below. Front: Toe total -10mm(5mm out each side) Ackerman +5°
    • @Duncan can you put the Link in, and measure all the power input voltages with a multimeter. Specifically looking for one that is low.   Then put the other ECU in that it runs on, and measure those voltages again with a multimeter?   If all of your voltages read normal on both ECUs, but the link is still reading low internally, your issue IS the LINK. If the voltages drop low on the multimeter while the Link is plugged in, but not other ECU, then the issue COULD be wiring in the car, or it COULD be the ECU. To rule out wiring, work out how with an ECU removed, you can trigger all the necessary relays, and then measure resistance from the pin that is reading low at the ECU, to the batteries positive power.   I have a sneaking suspicion your issue is the link, it's not reading the voltage properly, possibly a dry joint, or a Cap dieing, and because voltage is low, it's likely attempting to compensate on fuelling and the engine won't run.
    • Hi there, Does anyone here have the carbonetics slam panel installed on their R34 GTT? Or used to have one and got some pics of how it sat? https://carbonetics.net/products/1999-2002-nissan-skyline-r34-gtt-cooling-slam-panel?srsltid=AfmBOoo6Uz0nuxGI3qC0sn56KJI6PMgh0OvV-pbegsPDHTtTxz4IMljc I’m just trying to get an idea of how they sit once installed but these guys have no pics.  biggest question I’m trying to figure out is what the hell the 3 holes at the front of the panel are 😂 and where they bolt    Thanks in advance
