Desaster on my R33 GTR needs help. (Introduce myself)
I believe it is a r33 throttle body form any rb25det that will work, so I ordered one of these up, we will see.
if anyone else is wondering, they rotate nicely and with care can rotate them to any orientation without issue. in doing so I was able to eliminate the cross over hose from rocker/valve cover to cover, routing around the back and opening up the space above the coil cover, making the engine look much cleaner.
In Sydney. I didn't want to update the cluster originally for that reason of, I had no idea where to find someone who does calibrate the km's, also it's expensive af lol. Just wanted to make my faceplate look a bit more modern.
Hi there, have an s15 3.69 long nose abs diff in my r34 and would like to go to a 4.11 and 5 bolt shafts Does anyone know if pinion and crown wheels from a NON abs diff (short nose) will fit inside the abs (long nose) diff?
yes they "work" fine. Just like factory but they look shit. Kit came with a HD reverse camera upgrade but i was told if i install it i will lose the 360 camera. It's a small problem really. Only real big problem is the Polarization on the screen is horizontal same as my sunglasses. So the screen is black when wearing my sunnies unless i turn my head to the side 😵 . so dumb! Maybe it's a safety thing, My passenger can watch Netfilx while driving and i can't see it 👍
