Looking to buy a new radiator cap for my Skyline because I think this one is shot. I've got the part# 2143001F02 and it seems this same part is also the radiator cap for the Nissan Sunny B13?
https://goodstate.com.au/parts/72f01c08ec5ae1878e258c43e35b81aa?srsltid=AfmBOorhguaKBQN0nFfCaM7kjdreG3TrS4nbB3VWZWw8iFXGJtFP-jtw
I mean, the part number matches, so I'm inclined to not overthink it. These are some of the only guys in Aus I could find. Most radiator caps I find are 1.2 and I would feel more comfortable replacing with a stock 0.9 cap. I just wanted to get some kind of confirmation since their website does not show the RB25 or the Skyline as compatible. 🤷🏽‍♂️
https://www.sau.com.au/forums/topic/485764-r34-gtt-oem-radiator-cap/
I know this has been discussed before, but I can see the Fenix radiator is 1.1 bar.
https://fenixradiators.com.au/products/nissan-skyline-r33-gts-t-gt-rfull-alloy-performance-radiator?variant=40947446251678
1. Should I be worried about the extra 0.2 bar pressure that will be going through the whole cooling system?
Car is just a daily, only time it goes over 3K revs is when I'm merging on the highway or sick of being stuck behind a slow car 🤣
2. If I'm so worried, do I just get a 0.9 bar cap?
If you want to be pedantic and justify it. Higher pressure means it needs to be a higher temperature to boil over.
In the real world, it absolutely won't matter at all. You can also tell yourself that an alloy radiator can handle higher pressure than one with 20 year old plastic tanks (it will).
  • Like 1
Realistically, the biggest impact of the higher pressure cap in a daily car is a coolant hose that is on its way to failing will happen a little sooner due to potential for extra pressure in the system :)
  • Sad 1
@Kinkstaah yeah might just be me being paranoid with how much can go wrong!
@Duncan Looks like I'll get replacement hoses for the radiator soon after the radiator then!!!
@GTSBoy Is this the right radiator? It just says R34 and R33 so I'm assuming they all have the same radiator specs?
I read in a guide that there is a sensor on the bottom left? Do those still fit as well?
Edited by DraftySquash
It should be. It's the only option (other than the cross flow, which you don't want, and the one with the shroud and fan, which is the same rad underneath anyway).
As to the sensor, I dunno. I think the spot for it is shown blank on their photos. You would be well advised to a) look on your own to see the sensor is there and that you therefore need to accommodate it, and b) ask Fenix what their provision is. You might need to drill and tap the hole, or they might do it on request or as a standard option or a delete option. (Mine is in an R32, so it's not the same thing, and I didn't order it anyway, so I don't know what we did for mine).
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
