like the title says, I am asking for clarification as what stock throttle body should be used when putting front facing intake on r34 gtt rb25det neo engine? (shortest type possible, but stock size, proper electrical and cable connections and wont alter run-ability, as the stock r34 gtt is simply too long, as it has dual "baffles" traction control, type throttle body.) I know I 've seen this info below but couldn't locate it. r33 rb25det non neo? gtst? series 1, 2?
Weird the Gktech one doesn't have the 3 holes and is only a 5min install if you have the standard front bar.
Honestly, as someone on the standard PS4 controller, should be relatively easy to get gold. Remember you have more grip than you think.
Fitted some Advan AD09s to try next. Likely slower than the CR-S but should work in the wet and last longer. Off for alignment and the new plates worked a treat! I was finally able to hit both my drift and grip alignment targets with the same setup! Grip Front: Toe total -2mm(1mm out each side) Caster +7° Camber -3.8° Ackerman +15° Rear: Total toe +3mm (1.5mm in each side) Camber -1.5° —————————————- Drift as above but drop the front sway bar and change the below. Front: Toe total -10mm(5mm out each side) Ackerman +5°
