My Rb20det (r32 skyline) starts as soon as the key turns but it's running rough and has no power or acceleration especially when climbing hills. I notice the following symptoms:
- rev limiting (fuel cut) @ approx. 3000rpm sometimes lower on higher gears
- idle is steady
- when afm is removed doesnt go past 2500rpm
- in neutral only revs up to 4500rpm
- strong smell of fuel from exhaust
- no change to engine when removing 1 or 2 ignition plugs
- got a code 21 error and sometimes the exhaust temp sensor light will flash briefly
THINGS I'VE DONE TO RESOLVE THIS:
- replaced fuel pump (Walbro 255) but its really noisy.
- replaced filter filter
- cleaned afm with brake cleaner
- changed ignition coils to r35 (vr38dett)
- as per above removed coil ignitor
- flushed oil and radiator, but both are leaking
- checked compression, avg. 225psi each cylinder
- sonic cleaned all fuel injectors (fixed one leaking and one with bad spray pattern)
- fuel pressure approx. 40psi (aka 3kg/cm3)
- replaced iridium plugs with copper and gapped to 0.8mm
all stock, except 3inch turbo back exhaust, and ignition coils/igniter
Any help is appreciated. thank you
I just finished fixing a similar problem on my rb20, I’d double check your AFM or the AFM wiring. Mine didn’t have 12v on the power wire, as soon as I ran a jumper wire it ran perfect.
From my understanding there’s very few things that will induce that cut from the ECU so I’d be looking at the AFM for sure. Walbros are loud pumps so wouldn’t be too worried about that and it seems like you’ve checked the majority of the other spots
  • 1 month later...
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
