Hello again I just got my rb25 tuned yesterday made 450 forged internals and semi built head I went on a beer run and let the car warm up before I got on it and I did a small pull and then about a minute later the engine shut off. I towed it back to the house and been tearing into it today. It’s odd I cant turn the engine by hand to the right (intake to exhaust side) it has some wiggle then it stops and won’t turn any more but I can turn it to the left no problem. I did a leak down and all cylinders were in good condition. I’m so lost at this point. I checked cams in case they snapped and they are all good too. I think I’m going to pull the head off tomorrow just to see what’s going on because I don’t understand.
https://www.sau.com.au/forums/topic/485778-rb25-blown/
Well, it's too weird to be making any guesses. I'd have the plugs out and a borescope into the cylinders before doing anything else.
When you say
Do you mean to say that you can turn it over continuously? Like, it's not seized or blocked from rotation outright? Only won't turn forwards? If so, would sound perhaps like something has dropped into the timing belt area or has otherwise arranged itself like a ratchet pawl, so that it prevents rotation one way, but not the other.
https://www.sau.com.au/forums/topic/485778-rb25-blown/#findComment-7992553
When you say
Yes and that’s what I think as well and yes the rotation is continuous
https://www.sau.com.au/forums/topic/485778-rb25-blown/#findComment-7992554
3 minutes ago, Dose Pipe Sutututu said:
Most likely won't hold pressure, however it is still possible if the valve isn't bent
I just realized something I’m at TDC and my intake cam is at the timing mark the horizontal mark and my exhaust cam is at like 7-8 o’clock position not even close to the timing mark. I’ve timed these engines about 5 times now and always do it the same line up the 3 marks crank and two cam. How tf have my cam spun that far off. I’m gonna check all the timing system tomorrow
  • Like 1
https://www.sau.com.au/forums/topic/485778-rb25-blown/#findComment-7992567
Many possibilities, like cam gears coming free of the cam shaft and spinning.
https://www.sau.com.au/forums/topic/485778-rb25-blown/#findComment-7992575
So good news and bad head is off. Good news engine is turning again forwards continuously and pistons have very small mark on the top where valves hit it does catch a finger nail going to still ask machinist if it’s ok to run I think they will be ok.  On to the bad I took the exhaust cam off because the exhaust valves where the only on the pistons and it seems like my first cam cap (closest to timing gear) was eating into the camshaft and end up stopping it all the valves have the marks in picture.
https://www.sau.com.au/forums/topic/485778-rb25-blown/#findComment-7992588
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
