I would like to mention I've done research on this topic. However, I have struggled to find an answer and am here seeking advice.
I have an R34 Skyline GT-X (series 1), meaning a stock non-turbo automatic. 2 2-wheel drive IRS (no HICAS), and no viscous lsd option. It has an open diff, from my understanding it is a R200 ABS Open Diff 4.08 ratio 3x2 bolt pattern. I have stock GT axles. The car now has been manual converted and running a forged 25det making around 600hp. The open diff is a nightmare.
I want to upgrade the rear diff for sure. I am potentially interested in upgrading the axles as well as I know some of the other diffs can be put into my car if the axles are changed - also not really sure how they hold up with the power my car makes.
What is recommended?
I saw for sale a "R33 SKYLINE RB25DET 4.0 3x2 BOLT AXLE R200 LSD DIFF HEAD" for 750 NZD - is this a potentially good option? Would this be straight bolt on?
Thanks
https://www.sau.com.au/forums/topic/485787-seeking-r34-diff-advice/
You want the 5x1 bolt axels or convert to 350z 6x1 (or 300zx TT 6X1 axels)bolt axels with new flanges welded to stubs from leeson engineering or get a nismo gt pro "gtr" centre or find a gtr factory centre and swap that in to current diff with the new axels.
As it currently stands, you have a S15 rear end.
Keep in mind if you do something fancy like put R34 GTT shafts back there you may need to do something fun with your wheel speed sensors to keep ABS, as the GT has a different ABS setup to the GTT. (it is like the S15).
The simplest way is to put a helical diff in there from a S15. A more sturdy way given what you have is to consider a Nismo diff of appropriate lockage (i.e get the pro with different cams to go between 1 and 2 way).
The final way is to convert to something else, but keep in mind what you'll need to do with wheel speed sensors (i.e you will need to do what S15 people do).
FWIW, the tripod CVs in the 3x2 bolt axles are fine for typical road power levels. Like, probably up to 300rwkW. Maybe more. There's plenty of S chassis cars running that much power on them. They're certainly not as good as the 5 bolt ones, but they're not crap either.
I wouldn't go changing all that stuff for no good reason. There are completely aftermarket driveshafts available that will bolt to both the 3x2 and the 5 bolt stubs, that are much thicker with very good CVs on them. I would be buying those if I trashed what I have now.
  • Like 1
@GTSBoy @Kinkstaah Thanks very much for the replies!! So the car has been tuned @ 480kw on a dynapack dyno. ABS has already been removed from the car, so there won't be an issue there.
So far, I've had no problem with the rear axles. However, I primarily want to upgrade the diff for drifting reasons. Upgrading axles was rather something I was considering due to power reasons as well as if it was worth changing the whole rear setup while doing the diff...
I'm thinking of going with what @robbo_rb180 said: a 1.5 way GT pro diff with some new axles? What do you guys think? what axles would you recommend
Otherwise, there's a s15 diff for sale near me for a great price .. would save me a lot of money.. do you think this would do me good for the power the car makes?
thanks - sorry for being a bit of a noob.
A helical (ie, S15) diff would not be a good choice for drifting. The helicals are a great street diff, but they do have some odd characteristics that make them less suited than a proper clutch diff. If you get one wheel up in the air with a helical, it will act 100% as if it was an open diff and freely spin the airborne wheel. No drive at all. Drifting is rough enough and you're going to hit kerbs often enough that this is a joy killer.
Additionally, helicals are not pure magic. They work by jamming in the internal helical gears into the housing, and they do wear there. All the S15 diffs are approaching 25 years old now and they are all worn. So many of us that have them observe that there can be some delay and apparent slop in the way they engage and take up drive. I've just spent a bunch of money putting mine back into my car and am somewhat wishing that I hadn't. I should have just ponied up, worked out what it would take to get a Quaife into it, plus a new CW&P from Neat.
So, the GT Pro is by far the best option for you.
There is still no need to change to 5 bolt driveshafts. The increase in strength from the tripods you have to the proper CVs is not going to be large enough to justify the effort and expense in finding drivehafts and appropriate stub axles. Although, having said that, I think when you buy a Nismo diff they come with the necessary stubs. But this is complicated because:
  • Standard viscous LSDs have one long and one short spline, which doesn't work with the mech diffs, so they have to supply stubs.
  • Open diffs have, I think, spline lengths on their stubs that actually work with the mech diffs. So I'm not sure if they do supply stubs with the centre when you buy a centre to upgrade an open diff (as opposed to buying a centre to upgrade a VLSD). Note that the Nismo kits for different diff types all have different part numbers because they know the differences between the various diffs.
  • If you buy a Nismo diff for an S-chassis 3x2 VLSD you will get 3x2 stub axless with it, and if you buy for a Skyline chassis you get 5 bolt stub axles.
  • So you need to make sure everyone involved understands what you are doing and what bits you are working with before you drop your coupla grand. Otherwise we get a bitch thread next.
Following on from all that - if you need stronger driveshafts, and at that power level you may well need them, because drifting is anything but kind to them - then I'd be looking to buy actual upgrades, as I first mentioned. And they are universal so they will work with either type of stub axle.
Edited by GTSBoy
  • Like 1
These are the cheaper end of the stronger driveshafts I mentioned. 50% stronger than stock.
https://www.nengun.com/d-max/reinforced-driveshaft?srsltid=AfmBOopNJmSVvKiXvUoqd1iA6Sl6UssD06heku5ytVTGo9lN1gj8h-mG
Also, when I said "Skyline chassis" above, I meant Skylines with VLSDs. Not NA cars with 3x2 stubs.
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
