Hi all,
Just went to change the oil and filter and noticed a leak. Tough to see exactly where its coming from, certainly from the hot side
Any ideas ? or could it just be coming from the reservoir. Haven’t noticed the leak before and I regularly check under the car for leaks. Does look like its coming from up higher, and making its way down
Few pictures attached
Thanks
Well, it's red, so it's almost certainly PS fluid. Degrease it all off and inspect after a drive. If you see nothing, do more driving then look again.
And get yourself a mirror on a stick and/or a snake cam, so you can look in under/behind things.
