Auto Electrician Workshop Recommendation for Reverse Camera Not Working CKV36 (SYD or WOL)
Can anyone recommend a workshop that can repair a reverse camera issue for a CKV36? Started off intermittent but now never works - just shows a black screen with the steering lines when you put it into reverse. For any other purpose, the display otherwise works fine. Would prefer Wollongong area but will travel to Sydney to get it fixed. Dropped by a couple of local auto electricians and they did not know where to start with it (I suppose I prefer this honesty up front rather than spending chargeable hours and not getting anywhere!) Thanks.
Tunehoouse have sounded knowledgeable for our cars when I have spoken to them. I would hope the electricians you took it to at least first checked that the camera was getting power, the impedance across the unit was not 0, and there was continuity between the camera plug and the screen (much more specific technically).
If you have access to a wrecker for these cars, might be cheap to get a camera from a wreck and plug it in to see if an image displays. Of course , the wreaked camera may also be broken.
  • Like 1
yep it will be like that. Where do you mean by "down here"? This forum traditionally was an Australian/NZ one but we've been worldwide for many years now. So 100% state your location first so people can help by providing more localised informations (state your country, it helps a lot).
He said in the OP Wollongong area.
  • 1 month later...
Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement.
They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions...
I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
  • Haha 1
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
