Synthetic oil versus conventional oil
The car itself when driving doesn't sit too low. Front bumper is probably 80mm off the ground but chassis rails and everything else sits at least 120mm off the ground. Could possibly be the alignment settings I have now are pulling the axles out of the diff/hubs a bit but its all basically factory specs
Sounds like an issue with the car's height than anything else. -
Tried that ahahah, thats what broke my inner cv joint. Handbrake + clutch kick and then broke the cv joint bearing
Use the handbrake to load it up! Could try a S15 Auto LSD, brings it to a 3.9
