I’ve decided to swap out these old carrozzeria ts-a70w in the rear parcel shelf for some pioneers while I’m sound deadening, I’m looking at the wiring and none of it makes sense it’s all mixed up and a mess….
any ideas am I better off running new lines there is a lot going on in the boot with wires running everywhere and terminals everywhere.
Edited by 32pwwr
https://www.sau.com.au/forums/topic/485797-any-sound-system-gurus/
7 minutes ago, Dose Pipe Sutututu said:
Looks like it's going to an amplifier somewhere.
Might as well rip out the lot and run a new amp, and head unit with Android Auto / crApple Car Play
There’s no amp looks like at one stage there was as there is a separate black plug laying back there.
considered Apple car play but the double din means i sacrifice my aircon or gauges haha
Edited by 32pwwr
The original soundsystem had a small amp hanging under the parcel shelf. Thus, the original speaker wires in the rear only go as far as that amp. The input wires to that amp came from the front of the car and that may well be the loose plug.
There is absolutely no way that anyone who is not present standing at your car can help you understand that bunch of wires in your photos. It has clearly been modified away from what the original wiring was, and thus we can't know what we're looking at.
You just need to put in time and effort to identify where those wires come from. Once you understand that, you can then decide on what you want to do with them. If they are good sized speaker wires that possibly came with the previous speakers and the connectors on them will suit your new speakers and you're happy to run them from whatever amplifier (ie, even just the headunit) that they're currently already connected to....then you could just reuse them.
If they have been hacked and twisted together and so on, then abandon ship and start afresh.
  • Like 2
I might start fresh, there’s just to much going on to understand and no auto elec will come look at it for 2 speakers for a reasonable price lol and I’ve already done the front speakers myself.
I ended up pulling the wires and found only the green and grey lead to the stereo, the yellow and black were connected to nothing and just pulled them out
Jesus...
Rip it all out, start again.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
