Skaife’s 1992 Bathurst winning R32 GTR to race again
That sounds like it could be fueling or timing. Everything that you're describing is part of why it's taking me so long just to build a "base map" for a Haltech tune. I'm really trying to make everything behave as close to OEM as possible before I even connect the ECU and see how it runs against the real thing. -
It's a fun job...did a little write-up here --> https://forum.r31skylineclub.com/index.php?topic=159279.105 FTR, smoothed the idle out and the rb30 was more responsive...manifold vacuum at idle came up a bit (likely the base Orings leaking), and spark-plug colours evened out. An interesting little test, is to grab an eye-dropper/pipette and put a couple of drops of petrol in the old gauze filter, same again with new ones...see how long it takes to drip through 😃 Thing is the results are inconclusive because I replaced the injector connectors and fitted the intake runner spacer at the same time...but when you see & test the old gauze filters, there's little doubt this would've pushed fueling a little bit towards the thin side... ...btw... https://www.amayama.com/en/part/nissan/2891341l00 ....washer bottle cap, still available last time I checked.
By Watermouse · Posted
Where are u located? U got nothing on your sig There’s a place in Carrington (Newcastle) that refurbishes speedometers/gauges. They can also adjust the new odometer to the kms’ of the previous odometer and supply a certificate, also re calibrate the speedometer -
I liked the "adventure" video to find some mountains shaped like the cracker
