Hi there,
Does anyone here have the carbonetics slam panel installed on their R34 GTT? Or used to have one and got some pics of how it sat?
https://carbonetics.net/products/1999-2002-nissan-skyline-r34-gtt-cooling-slam-panel?srsltid=AfmBOoo6Uz0nuxGI3qC0sn56KJI6PMgh0OvV-pbegsPDHTtTxz4IMljc
I’m just trying to get an idea of how they sit once installed but these guys have no pics.
biggest question I’m trying to figure out is what the hell the 3 holes at the front of the panel are 😂 and where they bolt
Thanks in advance
Just walk away from the cooling panels. I've had one and it was a fancy carbon one from Japan (let alone a copy of one) and didn't actually line up with the GTT. Had cutouts and things. And probably more importantly, if you look closely at how your bonnet seals, there's a rubber strip on the underside of the bonnet that does the job you want this carbon panel to do.
  • Like 2
On 12/09/2024 at 10:43 PM, Milkmun said:
Weird the Gktech one doesn't have the 3 holes and is only a 5min install if you have the standard front bar.
@Milkmun Yeah I was looking at the Gktech one as well and just holds on with the 2 bolts at the middle and no front section that goes upwards.
I've watched one of the Youtube installations of it and the only thing with that is that I'd need to drill a hole for the screw that holds the oil cooler in A/T.
@Kinkstaah It's purely just to make the bay look cleaner and not have a gaping hole at the front 🤣 I'm getting some bad mojo from this panel and have a feeling it only works in S1 (even though they never mention it)
@Kinkstaah So... I took your advice and looked under the bonnet... is this where the rubber strip should be?
Would get the Gktech one then, it's 1 hole which would be straight forward to drill, plus it's a third of the price.span widget
Edited by Milkmun
Edit
On 13/09/2024 at 11:21 PM, GTSBoy said:
Look on the top of the radiator support panel. ie, look down from there.
oh whooops.. does that mean there  should be something clipped here? (bottom of image)
Yes, well, one or the other. On R32 (which is the only thing I can look at personally) it's on the rad support panel. You have neither, and it will need to be on one or the other. I must say that the arrangement of holes perhaps looks more like it lives on the bonnet underside on the R34. The rad support panel doesn't look like the R32 one at all.
A quick google shows....
That is what will seal with the bonnet closed. Follow it down while closing the bonnet to see where it ends up with the bonnet closed.
The panels don't do anything other than spending money, which this one will do just fine. :p
If you can get access to a guillo (or dremel), and a break press (I've used home made folders out of timber and a few hinges), and a dremel for notching, there is about $10 of alloy and some time involved with making one
I've made a few things like this, start with a cardboard template, measure twice, cut once
I typically then sand the edges, hit it with wax and grease remover, then wrinkle coat it, you can also add pinch weld to make it prettier
As for fittings, plastic push clips work
Use the saved money to buy tools
Or, make a cardboard templates and get your local metal fabrication joint to knock it out
When I was a young lad I was a sheet metal worker, we had heaps of people walking into the shop with small templates people wanted transfered onto  steel or alloy, usually paid for in beer
>$300 = "Jebus"
welll...you'd think so, indeed I did for a long time, but - after making my own fibreglass one, and in fairness, also making up fibreglass side and bottom panels to seal the intercooler>body gaps, my coolant temps plummeted. Like, average 76 degrees, thermostat temp. When set up properly, for sure they work.
I added one, it made the car hotter.... :D
Mind you, that one looked great, did nothing so I sold it on. If you make actual good working ducts as above, it'll definitely work.
This isn't that though, out of the box :p
  • 4 weeks later...
Bit late....but the one on my stagea has additional holes too, it is for clearance of the bolt heads which hold the radiator latch upright to the radiator support (ie, they are not to locate the panel)
  • 3 months later...
@DraftySquash @Duncan
he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car.
anyway I had a look at other cooling panels and came across this one
https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70
if you take notice it’s the same shape.
well thankfully the justjap listing has a description and it says :
- Nissan Skyline R34 GT-T Coupe (M/T -07/2000)
this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar.
im not 100% sure but im almost certain it will still fit a s1 bar
i misspoke, or this might be the other way.
someone sent me a low res pic of it on
It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets
If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
Edited by IM-32-FK
have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something.
It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar towards the condenser and radiator. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
Edited by IM-32-FK
  • Like 1
Yes, at least 10 years before anyone ever thought of making such a panel. Of course.
What I’m saying is that I never heard of a non gtr 34 coming with a cooling panel stock or factory option. Maybe they might’ve I don’t know
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
