JC71 Posted September 12, 2024 Share Posted September 12, 2024 (edited) like the title says, I am asking for clarification as what stock throttle body should be used when putting front facing intake on r34 gtt rb25det neo engine? (shortest type possible, but stock size, proper electrical and cable connections and wont alter run-ability, as the stock r34 gtt is simply too long, as it has dual "baffles" traction control, type throttle body.) I know I 've seen this info below but couldn't locate it. r33 rb25det non neo? gtst? series 1, 2? Edited September 12, 2024 by JC71 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/ Share on other sites More sharing options...
GTSBoy Posted September 12, 2024 Share Posted September 12, 2024 Bosch e-throttle. If you're going FFP you might as well put a proper ECU into the poor thing. Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993055 Share on other sites More sharing options...
MBS206 Posted September 13, 2024 Share Posted September 13, 2024 (edited) "Won't change runability"? It seems you're planning a major part swap without retuning... Edited September 13, 2024 by MBS206 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993062 Share on other sites More sharing options...
joshuaho96 Posted September 13, 2024 Share Posted September 13, 2024 On 9/12/2024 at 10:47 AM, JC71 said: like the title says, I am asking for clarification as what stock throttle body should be used when putting front facing intake on r34 gtt rb25det neo engine? (shortest type possible, but stock size, proper electrical and cable connections and wont alter run-ability, as the stock r34 gtt is simply too long, as it has dual "baffles" traction control, type throttle body.) I know I 've seen this info below but couldn't locate it. r33 rb25det non neo? gtst? series 1, 2? You are not going to do a direct drop-in. A complete front facing intake like the RB26 on an RB25 is a major change and transient fueling mapping which is already a bit of a guess will be completely off. Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993094 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 14, 2024 Share Posted September 14, 2024 DBW e-throttle conversion. Will drive better, idle better, have superior throttle articulation (change the slope however you want), proper cruise control, boost control (by limiting throttle max open rate based on boost / engine speed thresholds) etc. Everything the stock throttle can't do. Only downside, you can't open your bonnet and record a selfie video with the throttle at WOT yelling "RB Powahhhhh woooooooooo" 1 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993096 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 14, 2024 Share Posted September 14, 2024 1 1 1 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993097 Share on other sites More sharing options...
JC71 Posted September 16, 2024 Author Share Posted September 16, 2024 I believe it is a r33 throttle body form any rb25det that will work, so I ordered one of these up, we will see. Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993159 Share on other sites More sharing options...
JC71 Posted September 23, 2024 Author Share Posted September 23, 2024 I found two used throttle bodies both claiming to be from a R33 RB25DET, I bought both, when one showed up it has a large center rod with a flat side for the center drive of the TPS. The other has a much smaller center rod with a smaller cross rod through it making a "X".....this style matches what my rb25det neo engine has, so I will be able to use this throttle body and my org wiring and reuse the sensor itself. I don't know why the other has the other version (both said TB from S2) but no matter I was glad I ordered both, as I found one that will work nicely. Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993363 Share on other sites More sharing options...
MBS206 Posted September 23, 2024 Share Posted September 23, 2024 4 hours ago, JC71 said: I found two used throttle bodies both claiming to be from a R33 RB25DET, I bought both, when one showed up it has a large center rod with a flat side for the center drive of the TPS. The other has a much smaller center rod with a smaller cross rod through it making a "X".....this style matches what my rb25det neo engine has, so I will be able to use this throttle body and my org wiring and reuse the sensor itself. I don't know why the other has the other version (both said TB from S2) but no matter I was glad I ordered both, as I found one that will work nicely. Did you happen to read anything above anyone has said? Especially things like "it's going to need a complete retune"? IE, none of this will be safe to run once you plug it all in. And then secondly, the fact that pretty much none of your wiring will reach, and likely the throttle cable won't reach etc. 2 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993367 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 24, 2024 Share Posted September 24, 2024 15 hours ago, MBS206 said: none of your wiring will reach might as well go e-throttle 1 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993382 Share on other sites More sharing options...
JC71 Posted September 24, 2024 Author Share Posted September 24, 2024 (edited) I did read it all, but been restoring and fabricating classic custom award winning vehicles for 30 years, so I don't think some wiring and a cable will be a problem. doubt a retune will be needed, not with these changes, and not necessary as essentially everything will be "stock". just changing the location of the throttle body, wont make much of a difference, engine and ecu wont know the difference, still will get air, spark, compression, fuel, and sensor readings. All will still functions the same as same size and type of components used. additionally I am in the US, so in a few years if someone around here gets experience with tuning these cars properly and or I can obtain the proper software, program, etc. and experience, then maybe someday a tune will be done, simply to optimize potential performance. Edited September 24, 2024 by JC71 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993384 Share on other sites More sharing options...
GTSBoy Posted September 24, 2024 Share Posted September 24, 2024 3 hours ago, JC71 said: doubt a retune will be needed, not with these changes, and not necessary as essentially everything will be "stock". just changing the location of the throttle body, wont make much of a difference, Wrong. FFPs flow very differently to the stock plenum and it's a very long way from ideal to not address the per-cylinder mixture changes that result. Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993387 Share on other sites More sharing options...
TurboTapin Posted September 25, 2024 Share Posted September 25, 2024 (edited) 6 hours ago, JC71 said: I did read it all, but been restoring and fabricating classic custom award winning vehicles for 30 years, so I don't think some wiring and a cable will be a problem. doubt a retune will be needed, not with these changes, and not necessary as essentially everything will be "stock". just changing the location of the throttle body, wont make much of a difference, engine and ecu wont know the difference, still will get air, spark, compression, fuel, and sensor readings. All will still functions the same as same size and type of components used. additionally I am in the US, so in a few years if someone around here gets experience with tuning these cars properly and or I can obtain the proper software, program, etc. and experience, then maybe someday a tune will be done, simply to optimize potential performance. Don't ask questions, if you don't want to listen to the answers. It's not a good trait. As for tuning RB's and proper software and experience, it's been a thing in the US for decades. Edited September 25, 2024 by TurboTapin Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993391 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 25, 2024 Share Posted September 25, 2024 6 hours ago, JC71 said: I am in the US, so in a few years if someone around here gets experience with tuning these cars properly and or I can obtain the proper software, program, etc. and experience, If you can tune a JZ, you can tune a RB. Same same but different. Pork Gyoza vs Beef Gyoza, both Japanese. 1 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993392 Share on other sites More sharing options...
TurboTapin Posted September 25, 2024 Share Posted September 25, 2024 (edited) 18 minutes ago, Dose Pipe Sutututu said: If you can tune a JZ, you can tune a RB. Same same but different. Pork Gyoza vs Beef Gyoza, both Japanese. We've had RB's in the US and Canada literally for decades. They were always a popular S chassis swap. We could also legally import R32's into Canada back in 1999. Edited September 25, 2024 by TurboTapin 2 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993393 Share on other sites More sharing options...
MBS206 Posted September 25, 2024 Share Posted September 25, 2024 13 hours ago, JC71 said: I did read it all, but been restoring and fabricating classic custom award winning vehicles for 30 years, so I don't think some wiring and a cable will be a problem. doubt a retune will be needed, not with these changes, and not necessary as essentially everything will be "stock". just changing the location of the throttle body, wont make much of a difference, engine and ecu wont know the difference, still will get air, spark, compression, fuel, and sensor readings. All will still functions the same as same size and type of components used. additionally I am in the US, so in a few years if someone around here gets experience with tuning these cars properly and or I can obtain the proper software, program, etc. and experience, then maybe someday a tune will be done, simply to optimize potential performance. Feel free to not take the advice and knowledge of those who've been playing with these cars and engines specifically for about 20 years EACH. But we've all been there, done that. What you've just dribbled is total nonsense about not needing a retune, or no one in the USA being able to tune an RB. It seems you're just here for someone to tell you your bad ideas are good. For that, you're on the wrong platform. 2 Link to comment https://www.sau.com.au/forums/topic/485817-what-stock-throttle-body-to-use-when-putting-front-facing-intake-on-r34-gtt/#findComment-7993399 Share on other sites More sharing options...
