BNR32 front ABS speed sensors
yep thats the plan now. only problem is theyre impossible to find. I wanted to see if the crown and pinion from a non abs would fit cause those are a dime a dozen. There's a guy selling a non abs 4.11 with axles and a 2 way for cheap as f**k but wont suit my car unfortunately :(. Just gotta stay on the hunt for an abs diff and axles when they do pop up. For now just gonna rebuild my 6 bolt axles and take it easy on the car until i can get a new diff and axles
learn something everyday! In that case you would be better off just getting a R33 GTS-t diff, 5 bolt stubs and shafts. Similar to what the S15 guys do, at the same time put in a proper LSD centre as the viscous centre is junk. -
I wish they advertised and covered production cars Yes, I know there is a series, but without the support from the media it is hidden from view New "Super Cars" is too NASCAR for me, expecially now, with really only 2 contenders I want to watch 4, 6, 8, 10 pots race around together like the old days Yes, I am that old man shouting at clouds
Correct. They came with a viscous lsd or open diff with the sensor in the nose of the diff. Brakes from a GTT, shocks and hicas from GTT as well. Only thing drivetrain related that isnt GTT is the diff and gearbox which would be all na stuff
You would be correct. It is "technically" an abs sensor but it is used for vehicle speed to the na dash cluster
