Hey guys looking for abit of guidance, I have put a 25det into my r31 and am having trouble getting it to idle it will rev fine and not miss but on idle it runs like abit of a dog and stalls, I checked the tps voltage and it was 5.10 with car switched off I’m unsure if that is in the perimeters? other then tps could the iacv be the cause or potentially vvt ? I realise it could be a range of things but have to start somewhere, cheers
Edited by Liam2421
Grammar correction
https://www.sau.com.au/forums/topic/485822-rb25-into-r31wont-idle/
On 15/9/2024 at 5:00 PM, GTSBoy said:
At idle the TPS should show about 0.45V.
Yes, it could be the IACV and/or AAC. Got tbe clean and working to do what they're supposed to do.
Will not be VCT unless perhaps it is stuck on. Even then, it should idle.
Un able to check it at idle as it won’t idle for me long enough to try, best I’m able to do is with ignition on engine off and no matter where I turn the tps the voltage doesn’t change from 5.10, if I unplug afm it will idle longer but won’t turn off with ignition, have since swapped afm to no real change
Doesn't need to be idling. Just needs to be throttle closed with ignition on. Same same as idle from the ECU's point of view.
See, this is useful info, because this...
is not.
You should be able to sweep the throttle from closed to open and see it run from ~0.45V to whatever it maxes out at (which is not 5.1V, by the way - should be 4.something).
  • Like 1
Your engine won't shut off with ignition if your MAF is unplugged? I want to confirm I'm reading that right.
Yes it will continue to idle until eventually stalling between 10-20 seconds, still continues to idle even once  I hit the battery isolater or disconnect battery
is not.
Thanks for clearing that up, I see you comment on most posts it’s very helpful for less mechanically inclined people like myself so cheers,
could you recommend other things to check ? All I have done to this motor since seeing it run fine in another car (completely stock)  is install a Freddy plenum and a 3076 on a top mount , replaced plugs and have split fires on the way currently
What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
You don't lose spark if your battery isolator isn't wired correctly and the ECU still has power from the alternator.
Car has an epic wiring problem. Sounds like power connected really really badly in places. Possibly a power pin on a ground pin for the ECU, and constant power in locations that should be switched ignition.
It needs someone good at diagnosing electrical, a good multimeter, and someone with the wiring diagrams to match the engine loom that has been put into the car, and wiring diagrams for the body side of things from the car.
Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
  • Like 1
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
