https://www.supercars.com/news/breaking-news-toyota-to-join-supercars-in-2026-with-gr-supra
You know what's next don't you? Nissan is going to throw their cap in the ring too. Then, sweeeeet aussie race series going on.
  • Like 3
https://www.sau.com.au/forums/topic/485830-supra-back-in-v8-supercars/
Good news for the series, now everyone is running on the same chassis and suspension saves $$$ on development and setups will carry over. Hopefully they make the engine sound better than the lexus gt3 v8.
Biggest issue will be panel damage as guard is part of the bonnet and be hard to make a nice looking part line to separate it all.
Damn it
"The GR Supra Supercar will use Toyota’s 2UR-GSE all-aluminium, quad-cam V8 as its baseline engine."
There might be no BMW in it! 😢
Regardless, this will be a great addition and I'm keen to see it.
I was going to say "What you talkin' about Willis?", on the basis that the rest of the Supra apart from the badge and the "styling" is BMW....and then I realised that there'd be no Supra chassis present anyway.
So as you were.
  • Haha 1
Looking like they will have a 1:1 scale model at Bathurst from reports.
Hopefully more manufacturers join now too and bring some fresh dollars to teams. I know a team that could use it 😅
So as you were.
Maybe use the dash unlike the the mustangs coreflute one.
I know our cars only use the mirrors and door handles from production car everything else is modified or replaced with a few components.
  • Haha 1
I wish they advertised and covered production cars
Yes, I know there is a series, but without the support from the media it is hidden from view
New "Super Cars" is too NASCAR for me, expecially now, with really only 2 contenders
I want to watch 4, 6, 8, 10 pots race around together like the old days
Yes, I am that old man shouting at clouds
  • Haha 1
The future is now, old man. - iFunny Brazil
to be serious there is plenty of good racing out there and is generally shown on Blendline TV
https://youtube.com/@blendlinetv?si=IVqWM4QFdqRsG12S
The speed series was alright at QR a few weeks ago. The production car enduro and TA2 were good to watch.
  • Thanks 1
Cheers for the link, subscribed
One of the first ones that came up...LOL
https://youtu.be/Tc4Pf3qiAB8?si=jk2dSBAbN9CNyYEh
  • Like 1
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
