R32gtst rear wheel bearing
Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car.
So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings.
Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car.
A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
  • Like 1
Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
No. Not true for any non-GTR R32. I think even the GTS4 has the GTSt knuckles with eye type lower shock mounts (as opposed to GTR fork lower shock mounts).
The only R chassis in which something like the quote claim is true is the R34, on which the turbos have the fork type and the NAs have the eye type.
**Edit: Actually I reserve the right to be wrong about the above statement. It might also be true on R33s. My memory on those shitboxen has faded too much.
Edited by GTSBoy
Remember, your car is 30+ years old now, and who knows what drifters from the 90 in Japan + whoever had the car over the years have done to your car (before trying to return the car to "stock" condition and auctioning it out of Japan + whatever's been done afterwards).
Always pull the parts in question out, measure and investigate. A lot of stuff can be sub'd out (on 90's Nissans and Toyotas), so as a general rule of thumb, pull out and measure then investigate.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
