Front tower strut brace options
Hi folks, what options exist for PNM35 or what models share the same dimensions and fitment for the front top of tower strut brace.
I have seen a few options pop up through Google, the Ultra Racing Australia for one. I have seen some eBay ones that claim they fit C34 and M35 but can't find details if to work out if its true.
Also found Taiko / TEMA4x4 claim the one type fits:
- Nissan Stagea (2-nd gen; M35) 2001 - 2007,
- Nissan Skyline (V35, HV35, NV35, V35, PV35) 2001 - 2007
- Infiniti G35, G35X (3-rd gen; V35) 2002 - 2006
But not sure how true that is.
Anyone fitted one or know of someone using one and can confirm what does fit?
instead of spending money on a meagre benefit, why not spend money on things more useful? Like suspension joint bushes, dampers (the thing the goes inside your springs), oil + filters etc.
tl;dr tower braces make way less difference compared to your tyres.
20 hours ago, iamhe77 said:
Anything for a 2003-2005 G35 will fit an M35.
Just be mindful about clearance if you're running a plenum spacer or runner spacer.
Yeh not doing anything with spacers at all, ty for the info
Yeh a meagre benefit, what strut tower brace are you using? Eventually all the suspension and tyres are done and you get to ... meagre benefits. Narrow end of the wedge, all that stuff.
10 hours ago, GTSBoy said:
But you can stand next to your strut brace with the bonnet up in the Bunnings car park and people can see it. Can't see dampers.
Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
  • Haha 1
  • 3 weeks later...
On 19/09/2024 at 9:22 PM, PNM35 said:
..... claim they fit C34 and M35 ....
no way in the world does the same strut brace fit both, they are totally different width, PCD, angle for the strut tops. also the M35 would need to be way higher to come up and over
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
