Hello all,
I am looking to upgrade my transmission to a CD009. My tuner referenced me to a local who was doing the same project as me, but didn't finish and is selling. My tuner knows the person and has vouched for the quality of parts being in good condition.
He is offering for £3,500 (AU$ 6,815.93)
  • CD009 gearbox with RB25DET bell housing fitted
  • New Clutch Fork (fitted)
  • New Release Bearing (fitted)
  • OS Giken STR2CD twinplate clutch with brand new rebuild kit
I have absolutely no idea if this is a good deal or not. I appreciate any insight from those who know these things better than I.
Thank you in advance.
Edited by IXMandalorianXI
  • IXMandalorianXI changed the title to ['96 r33 GTST] Need some help gauging how much I should pay for a CD009 transmission kit.
OK, well, being realistic:
  • RB25DET gearbox (new, from Nissan), A$4k.
  • Good clutch, >A$1k, possibly $2k.
So, you're already into the ballpark just with those two things and to stay 5 speed.
Someone has borne costs and done work to put the RB bellhousing on the CD009, and there's some other parts included. It seems like a reasonable price to me. It's not as if these things are lying around where you can just pick one up (the whole kit, readyish to go) and/or play off one vendor against another. So the pricing has to seem reasonable to both you and the seller.
  • Like 1
Seems a reasonable price, some other things to consider, driveshaft & xmember, you'll need to run the speedo off the abs, an after market lever/bracket.
You'll most likely want to change the diff ratio, do you need any kind of certification in the uk for it?
If the car is quite low, the cd will hang down lower than the 25 box.
  • Like 1
I run a CD009. See my DIY for info on what I spent. 6800$ isn't cheap, but it's not terrible either.
Keep in mind, you'll still need the following parts.
- Shifter relocation kit
- Trans Mount
- Driveshaft
- Slave Cylinder
- Rear final drive (This doesn't have to be done right away.)
- Some new way to detect speed.
Edited by TurboTapin
  • Like 3
For the sake of cost comparison, I’m currently embarking on putting a new 5 speed into my R33. I imported a new RB25DET gearbox from Japan, which was about AU$3.3k delivered to my door. It was a very slow process (~2 months) and I got extremely lucky with the exchange rate. The twin plate clutch I bought was about AU$1.8k. I've also had to buy all the additional parts required to convert the gearbox from a pull type clutch to a push type clutch. Total cost is about AU$5.5k, so GTSBoy is pretty close to the money.
  • Like 3
You all are absolute legends! Thank you for helping me put this into context with your comparisons!
If anyone is chasing a gearbox in Victoria. There's brand new r34 rb25det gearboxes being advertised for $3200 pickup from Mornington Nissan. I posted the ad on a different thread a while ago. Still see the same ad up.
  • Like 1
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
    • I made an extension of the item circled above in red that is hard wired to the battery and tucks away nicely in the engine bay, could easily do the same if it in the boot, just run the extended cable out under the bonnet or boot lid, I then just stick the charger on a milk crate to get it off the ground
    • It's purpose will be to stop the regulator plug from leaking oil. As GTS said, if it seals properly, it will mainly just have the effect of slightly higher oil pressure. I'll assume tolerances/fitment in the relief valve aren't that close that the washer being missing won't let it vent at 100% capacity too.
    • I put the charger in the engine bay and run the power cord down through one of the holes in the undertray, or at the back end of the engine bay, any time I need a car to be on a charger outside. In fact, I bring the extension cord up through into the engine bay so that it's not dragging around where it could get wet, or easily unplugged.
