as we all know the Q50 stereo from factor has no RCA outs so i bought a Kicker output line convertor to use from the factory sub.
but im wondering as the device has L+ L- R+ R- which ones do i use for my subwoofer?
its only going to be 2 wires as im not worrying about doing my stock speakers just my sub.
do i just use the 2 L+ L- or do i use a combo of L+ R- or what?
I would just use one channel, if you use L+ and L-.  I would connect the R+ and R- input wires together, since it seems to have a 12V input, it might have some small preamps in there and you don't want them sitting with open circuit inputs.
All 4 wires from the head unit into the converter. That's both channels, so you do not lose any bass information that might be in one channel and not the other (which decent music should have, but I'm sure the shit that the kids these days are listening to probably doesn't).
Connecting both channels with alleviate the floating input problem highlighted by Greg above.
As to what you should do with the outputs from it - they should also both be connected to 2 input channels of an amp that can sum the two channels and yield a single low passed output to a single channel. There is often a switch on channel amps to achieve that goal.
If you're just listening to modern electronic music, then you can probably ignore the fact that there's two channels and just listen to one of them. If there is missing information it will probably only improve it by not being able to hear it anyway.
  • Haha 2
i was thinking that the 2 wires that go to the sub from factory has some sort of preamp like you mentioned and also a lo Pass filter to get just bass.
now that will only use 1 channel and that really should be all i need for a sub?
if i was trying to put a set of speakers in the back i can understand cutting into the left and right speaker wires.
i will try how im talking about doing it and if that is crap i will do it the way of all wires.
thanks for the input guys.
The existing factory sub feed should already have a sum of L+R and a low pass filter, so it probably isn't necessary to take another L and R feed from the HU.  If it didn't have a factory sub output, then that would be the best option though.
Does your new amp not have speaker level inputs?  that would eliminate the need for the speaker - line level converter completely.
i have 2 MTX thunder amps they do have the line input aswell but i have no idea where the connectors are to use.
so for ease of being able to run 2 sets of RCA leads im just using the convertor.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
