Hey guys
I'm pretty sure this question was asked before, I had an HR34 before, got another one again and I never gave much attention to this but wanted to ask you guys about dropping or pushing bonnet problem. ER, HR got pretty heavy steel bonnets, I'm sure S chassis and other R chassis gens also got heavy bonnets.
I used to push it after I gently put it down on the latch but I saw some videos guys dropping it from 30-40 cm and some say it's more reliable way to make sure it's safely closed. I let it drop a couple times from like 30-40 cm and it's locked no problem but it gives me that bad OCD feeling after that that something is damaged lol, the bonnet rubbers is there, guess they handle that little fall energy well and the latch itself is what stops the bonnet right?
Talked to other Skyline owners, some say both methods are fine, some against dropping it by any means, some drop all the time no problem.
So I'm like confused if I was doing it wrong or not and if I already messed up something.
...and jealous of my friend's Z, dropping aluminum bonnet feels so much right and better haha
https://www.sau.com.au/forums/topic/485854-er-hr-bonnet-question/
Just now, GTSBoy said:
I would say 100% that it doesn't matter at all.
I have an Al bonnet and I drop it sometimes, push it others. Have done so for 25 years and there's no way to tell that either has caused any problems (because there are no problems).
Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
