Fake ARP bolts?
GTSBoy
 Share
Hi Gents,
Someone I know (experienced engine builder) built an engine. It had some chinesium rods that came with ARP 2000 bolts. One failed on the dyno, destroyed the whole thing. The only possibilities are:
  • Installation error. Possible, but we should discount it almost 100% because he knows what he's doing. He doesn't discount it that much, because he's being hard on himself.
  • QC/QA problems with ARP products. I'd like to discount this, but I have heard a number of stories about similar failures, and stories of some builders buying 2 sets of everything, x-raying everything, and picking only those bolts that they are completely happy with. This behaviour coming from anecdotal stories of ~1% failure rates. 1% of all rod bolts failing would be about 1000x higher than I would expect to be anywhere near tolerable. If I were ARP I certainly wouldn't even be selling the product if they were dying at that rate (for non-installation error reasons). So, I would prefer to discount that possibility too.
  • Fakes. Specifically, fakes being sold bundled with cheap rods sets from CCP factory B in Shenzen, or wherever the stuff is being made this week.
So the question here is, does anyone else have some horror stories that would point to fakes being circulated in this manner?
  • Sad 1
Heaps of historical info on this, a quick Google gave dates back to 2012, all talk about identification markings, dimples, shapes of mounting surfaces, washers, that are concave or something to match the fasteners mounting surface, which ARP states that if the washer, if it uses a washer in its application, isn't the right way around, it can cause premature failure,  even if it was torqued up correctly with whatever lube is meant to be used
There is even talk about getting the bolts Xrayed to check the structure, one was about some builder getting multiple sets of bolts, having them Xrayed, and picking from those results
Nowadays identical "looking" fake parts, in identical looking fake packaging are everywhere, with all the markings and stuff, the only way you know they are not legit is Xray or when they fail
I assume if you don't want fake parts, and don't have a Xray machine handy, is to get them directly from ARP in the USofA, aftermarket rod and head bolts aren't something to take for granted
Imagine building a big dollar build only to find you lunch it because of an inferior fake fixture let go 😫
Yes. This engine cost a very large amount of money to build. It's a Frankenstein necessitating lots of custom parts and lots of fabrication and fettling to get things like big ends to clear the bottom of the bore, etc etc. The rods and bolts were supplied by the owner. Hence why the rods were Chinesium. Some lessons need to be learned the (very, very) hard way, apparently.
I was aware of the stories going back about that far as well. I just wanted to see if the reality was as bad as the fear.
My guess is, cheap rods, came from a site selling lots of cheap things, and likely a lot of knock off stuff.
I get doing a cheap build, but I don't get doing a huge dollar build, and then skimping on something even like the rods, and likely the bolts to go with it, especially if heaps of stuff had to be fabricated!
I wonder if there is much to tell without knowing where the bolts where bought from.
If it comes from Amazon or similar all bets are off. Can't trust them. And I fear not everybody knows that.
Wasn't it @TurboTapin who ended up with the fake fuel lines recently? The submersible ones which very much weren't submersible at all.
It kind of applies to everything nowadays. Doesn't matter if it's hardware or electronics. The fancy camera might have internals swapped out for cheap knockoffs. The hard drive will report a certain size but not actually be able to write it all. Shit like that.
A bit depressing but the reality is you really have to be weary of where and how you buy stuff :/
Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar. :/
Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
Edited by TurboTapin
Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
 Share
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
