I have recently fitted a Nismo GT Pro Center second Hand buy still in the box
i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD.
The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
https://www.sau.com.au/forums/topic/485866-nismo-15-way-stub-axle-issue/
From memory and please correct me if I have this wrong, the nismo that come with half shafts are specific for that diff centre. You may be able to find Nissan ones that match up but you'd need to understand what nismo are doing.
Best option is get  a pair of 5x1 axles, they usually don't cost that much and direct swap over for the 3x2(6 bollt)
  • Like 3
Actually, the best option is probably to get some of the stronger aftermarket driveshafts that have both the 5x1 and 3x2 pattern on them, so OP can do whatever the hell OP likes with the diff in the future and not have all this angst.
I posted a link to them sometime in the last 2 weeks, I'm sure.
  • Like 1
14 hours ago, OO Dan OO said:
It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
13 hours ago, GTSBoy said:
AFAIK, the length of the shafts has NOTHING to do with the ratio of the diff.
 The manual says a lot about the different ratios requiring different shafts.
all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs.
The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me.
I'm hating Nissan R200s more than ever now.
Ok another question. I have everything back in the car I have a very Uneven part of my driveway and one wheel is nearly touching the ground. Only the one barely hitting the ground is spinning. There are no weird noises when driving. Jacking the car up and turning one wheel, the other does not spin and same if I turn the wheel on the other side. But when I put the car in gear and drive, (in the air) both wheels spin. Is all of this normal?
No. Not normal. Mech LSD should turn the left wheel forwards when you turn the right wheel forwards. Open diff does the reverse. If the opposite wheel does not turn at all, I cannot explain what you're experiencing.
Something must be f**ked.
sounds like you've just described a helical/torsen diff, when you load up the rear wheels with the handbrake, then I'm assuming both wheels will then spin
Yeah, but surely no-one could hold either of the possible diffs in hand and mistake one for the other.
either that, or the said LSD is worn OR the initial torque setting (being a Nismo one, I'm assuming it has the adjustment on the RHS when you pull out the stub axle) it is set so low it's not engaging
I will test out today. I have a Torsen in My 1600 and it's great.
54 minutes ago, GTSBoy said:
Or had the living shit beaten out of it trying to drive the stub axle in....
It was doing the same befor I tried forcing the stub in. It was the C clip that got deformed. The inside and Stub look fine
I should have had a better look at it before I threw it in. I took the guy's word for it that it was genuinely a new 1.5 way and not what he pulled out of his car. But it looked brand new and had all new larger Crownwheel bolts
The struggle is real with lower ratios, has cost me a fortune making my 3.5 work.
Pull it apart, stuck one stub axle in a vice spline facing up, then stick the centre on. Insert the other stub axle then apply torque wrench. Report back. I suspect it's borked. The good news is they're pretty simple inside, bad news is parts for the Nismo stuff are hard to come by.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
