R34 GTT RB rough idle problem with weird RPM gauge fluctuations
Big sump with a quaife front diff should be you’re first modifications big sump will keep the engine alive and quaife front diff will transform how it handles
I would be doing the build in stages (I don't have money to do it in one go).
Mine is boring, have a pair of Mission 701 8" book shelves, hidden behind a 3m wide entertainment unit away from the kids, matching centre with rear Mission LX3 with 1x tweeter punched in already. Sub (now with a blown amp) was something I built about 15 years ago. Has 1x Dayton 10" HF driver and 1x 500W O-Audio plate amp, enclosed in a 90L ported enclosure tuned to about 25hz. Goes pretty loud and you do get mild chest compressions but not enough. Have updated the receiver since, I now run a Yamaha RX-V6A just purely for all the integration and shit with streaming services and e-ARC. I do want to get this: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html Realistically without a potential divorce, this is better: https://www.selby.com.au/price-promise/tonewinner-sw-d4000-subwoofer.html -
I joined this group years ago when I got my hands on an R33 GTS-T and was excited to get some mods on it. Unfortunately, I had to do the adult thing and sell it to buy a house. Fast-forward six years later, and I have been blessed to be in a position to buy an R33 GTR next year. I am getting close to buying my dream car, I would like to get the community's advice on modifications. I have researched mods in the past but I feel newer and better things have come out since then (2018). Goals: I would like to have a 400-500hp daily driver. I would also like to get the engine dressed up (Wire tucks, rocker cover pain etc etc). I would also like to use it for track days but more for fun rather than competitions. I am moving to Brisbane, Australia so any good mod garage recommendations in the area would be appreciated.
Thanks everyone for the replies/suggestions on my issue here. I'm still trying to diagnose the root cause of this. Things I have done so far: A week ago, I disconnected my 12v constant relay mod and returned it to the stock FPCM wiring: I could hear the sound of the fuel priming was different because of the FPCM limiting the amount of volts going to the fuel pump. From memory I think it also primed to 43psi. It was very hard to start it. I don't think from memory I could start it at all. I had to then ground the fuel pump to the chassie and then it could start after a couple of cranks. Fuel pressure did drop a bit to about 45psi (i think). It was idling even worse than before. 🤔 It was also doing the same weird RPM tacho thing. So I've returned it back to the constant 12v relay mod for now as I investigate more. Right now, I'm in the process of deleting my aftermarket immobilizer, an old Japanese turbo timer, and another aftermarket transponder immobilizer that the previous owners put in years ago (from sexspec days). Just curious to see if this whole bird nest would cause some weird electrical problems. The Viper 5900 immobilizer stopped working a few years ago, and I pulled out the main fuse on it years ago to stop it from being a parasitic battery drain and I haven't bothered to clean up the mess there, so now is a good time to. There was a RPM signal wire that spliced into the RPM tacho signal from the ECU harness. I've taken it out. I've already pulled out the Viper immobilizer and returned all the joints wires/splices back to factory. I let the car idle and it's still the same idle and RPM tacho idle issue. Now I'm going to delete the turbo timer and the other key transponder immobilizer (autowatch) and return splicing/wiring back to factory setup. Just to see if this might be causing some electrical issues. It might not, but I just want to get rid of it anyway. True!, I was actually thinking this the other day. I will check with another new vac line to make sure this is not the issue. This is actually on my to-do list, and you might be right, this might be a shit batch of fuel because I filled the tank up to 3/4 full from near empty, then I went to the shops and it happened straight after that. I've always filled up from this servo for years with no problems, but yeah might be my first batch ever batch of shit fuel from them. Will be doing this next when I get my hands on a container/jerry can. I just didn't think to do this straight away because it doesn't really explain why the tacho RPM thing is happening. Maybe I'll chuck some injector cleaner in the new batch too?
