HyperGear vs Pulsar Turbo RB25DET
Hi!
I’m looking to replace my current turbo on my S1 RB25DET in order to make 600HP but maintain responsiveness. I’m looking at the HyperGear ATR43SS-3 in T3 .63 A/R or the Pulsar PSR3576 Gen2 T3 .82 A/R. I’m still learning how turbo sizes effect lag, response, and power band. I’m looking to see if anyone can share their experience with either of these turbos or can recommend another to meet my goal?
These are my mods:
• Running 91 octane most of the time and occasionally E85 on track days
• top mount twin scroll manifold
• 44mm external wastage
• 1300CC fuel injectors
• mishimoto intercooler M-line
• 3in intercooler pipes
• g-reddy intake manifold
• link g4+
• NZWiring trigger kit
• GTR R35 coilpacks
•  built bottom and top
• 4” down-pipe and exhaust
Edited by Eric0
Added type of engine
30 minutes ago, Duncan said:
Hey Eric, it will help to put your location in your profile. 91 Octane is the lowest quality fuel available in Australia so I'm thinking maybe you mean US 91 not Australian
Hi! That is correct. 91 Octane US. probably similar to P98 AUS.
I’ll update my location
  • Like 1
93US is 98RON. 91 is a little on the low side to try to push to 600HP, but at least you can control boost to something more conservative when you're not on the good stuff.
Also, we should check. Is that 600HP at the flywheel? Or using the usual pony power yielded by US roller dynos?
 Gotcha! Thank you for the correction.
The goal would be 600 bald eagle (screech) pony power yielded on a roller dyno, but I’m more interested in responsiveness at low RPM and full-boost before 4000RPM.
well....I'm no turbo selection expert so I'll leave that to others, looks like you've got what you need from a supporting mods side though including the twin scroll manifold; that means you really want a twin scroll turbo to not waste the advantage, it will make the same boost/power a couple of hundred rpm sooner than a single scroll turbo
Awesome! Thank you for the confirmation. We’ll see if anyone has experience with HyperGear, Pulsar, or other turbo brands with good response and overall power.
After more research, I’m leaning towards the HyperGear ATR43SS3 ProR with .63 turbine. This a dyno graph from an RB25DET Neo with following mods:
• 1650cc injectors
• adaptronic plug-in ECU
• 600x300x81mm Intercooler
• 3in exhaust
• 4in downpipe
• R35 GTR Coilpacks
• twin scroll manifold
• twin 50mm wastegate
What do you think?
Honestly:
Buy a name brand turbo. Garrett or Borg Warner. Anything else you will be chasing "but why doesn't mine end up like the dyno graphs the sellers post?"
Buying a brand name turbo gets your result right where other people with the same turbo experience.
Also, 600whp in any country - expect your engine to become a consumable. If you're okay with that and can plan for that then all the power to you. Also consider your clutch will suck and your grip will be less than stellar.
Aim at 450whp. You'll have a better car and more fun actually using it, and it'll probably be faster for every scenario with the one exception being drag launching it on drag radials at a drag strip where you might be a tenth faster.
Sincerely,
Wiser, cooler heads.
 Share
    • Has anyone found the right offset for front  wheel 18 x 8.5 clearing brake caliper?
    • Honestly: Buy a name brand turbo. Garrett or Borg Warner. Anything else you will be chasing "but why doesn't mine end up like the dyno graphs the sellers post?" Buying a brand name turbo gets your result right where other people with the same turbo experience. Also, 600whp in any country - expect your engine to become a consumable. If you're okay with that and can plan for that then all the power to you. Also consider your clutch will suck and your grip will be less than stellar. Aim at 450whp. You'll have a better car and more fun actually using it, and it'll probably be faster for every scenario with the one exception being drag launching it on drag radials at a drag strip where you might be a tenth faster. Sincerely, Wiser, cooler heads.
    • I've driven it around "in da hooodd" and it seems ok, have driven it around with the A/C on as well to generate more heat. So far no leaks. Yet to do a long drive OR a track day in it, so both will be the tests. I think if I were to do it again, I would just plumb the water return straight into the intake manifold's bleed ports (un-used) on the top side, noting that I have an aftermarket one. I hope this works well, because I cannot be fked working on the car ever again     In terms of your usual highflow kit, I would just return the water to the hardline behind the head.
    • I know. It was there when I bought it, I don't know if I hate the scrape or the totally wrong coloured "touch up" paint more. I do plan to fix that when I can build up enough confidence 🤣
    • Do you have a link to the kit you bought? I don't have anything helpful to contribute other than suggesting to make sure that you do it right. It's a pain now, but it will be even more of a pain down the line if you have to fix it again. I've been ignoring a small leak on that return line fitting in my car. Still weighing up what to do with it. Jonny @Dose Pipe Sutututu has routed it back to the front of the engine to make it less painful. See this and following comments in his build thread. Not sure how it has been holding up since though.
