GTX series turbos, albeit reliable are quite dated now.
I run a Garrett GTX3576R Gen 2 with a T3 1.01 divided housing and I get 0.8bar of boost by 4000rpm and about 4600rpm is when it's all in (1.8bar) on a 2.5L, VCT NEO, 264/272 cams + usual mods.
Makes a sensible 437kW on E85. I do rev the motor to 8600rpm but at about 7500rpm or so it's not making anymore power.
If I had the opportunity to do it again, I would get a Turbosmart 6262 or a Garrett G35-900. Probably same response but will go 500kW+
  • Like 1
4 hours ago, Eric0 said:
I’m thinking of parring the G30-660 with a T3 .82 twinscroll. What do you think?
Which brand turbine housing are you getting?
Garrett seem to have dropped focus on anything twin scroll as of late. They only have it in T4 1.06.
That’s what I’m noticing… seems like a popular size is 0.82 A/R, I’m considering this:
T3 twinscroll .82AR, but I’m unsure what brand because I’m not seeing Garett having the option.
Awwww, the 7670 was the best turbo I ever had! But it (and the 660) is probably 'too big'. It also does come in twinscroll and T4, waaaah, return the Garrett!
Realistically either is going to be great, presumably you can find a suitable housing for the rear. I had a T4 1.05 rear with the EFR (it's the only option, too) and it was great response wise, but I also had a 2.8.
Garrett's 1.05 might be alright? I mean they make it for a reason after all. Surely they don't expect the G30-660 to be suitable for like a 4L motor only and couldn't conceive of having a smaller housing for a smaller motor...
Those are some serious numbers! Based on the input I’ve received, seems like the G-series would be the move for same power and response 🙌🏾
Thanks for sharing, and confirming that a G-series turbo is the move! I can post my before and after dyno results and see what changes going from a GTX to G-series has
  • Like 1
I’m seeing T3 to T4 twin scroll adapters. This should work?
https://privatelabelmfg.com/products/precision-works-t3-to-t4-divided-turbo-flange-adapter?variant=34085762138250&tw_source=google&tw_adid=&tw_campaign=18293857672&utm_term=&utm_campaign=**LP+Shop+-+pMax+-+Precision+Works&utm_source=adwords&utm_medium=ppc&hsa_acc=8464848152&hsa_cam=18293857672&hsa_grp=&hsa_ad=&hsa_src=x&hsa_tgt=&hsa_kw=&hsa_mt=&hsa_net=adwords&hsa_ver=3&gad_source=1&gbraid=0AAAAADla3MIVCZh3G3-4mL4aDYDUhP9n8&gclid=EAIaIQobChMIo9q-2PyEiQMVmA6tBh3enzi_EAQYASABEgIgnfD_BwE
Feels kinda silly stacking plates and adding another gasket.
Sorry for some reason I thought you had a T4 Twinscroll manifold, not T3! I wouldn't put adapters on adapters. Just another gasket to fail or thing to sit in the wrong spot or other annoying complication.
  • Like 1
Well… maybe I do go back and look into the 7670? I’m seeing a .72 T3 twinscroll option.
how does the spool compare to the g30-660 series?
Issue with this are gaskets failures (x2) as mentioned above also it raises the turbo up further which may cause packaging issues etc.
I suppose if you have an experienced fabricator around, you could cut off the T3 flange and weld a T4 divided flange.
Another option (probably better) is to find an experienced turbo builder and they can machine a turbine housing to suit.
I would even ask Tao at Hypergear to machine and send one over to you. Might end up cheaper for you.
I’ll reach out to him and see what options we have on building a custom housing. I’ll report back
9 minutes ago, GTSBoy said:
Close, but it’s not a twinscroll housing :( looking for a divided T3
Ah, yes. I forgot that part.
At this point I would concur with the earlier suggestion of having the manifold modded to get a T4 TS flange put on. I don't think there is a T3 TS housing option for these.
On top of that, there is the whole problem of what is your expectation for a wastegate?
Edited by GTSBoy
I’ve reached out to HyperGear to see if they could build a compatible exhaust housing. We’ll see what they say!
I currently have an external 44mm tial wastegate on my manifold.
10 hours ago, Eric0 said:
Posting an update:
Contacted HyperGear, Tao said he might be able to build a T3 .82 TS Vband! Waiting to hear back on cost and shipping.
Update 2: To make a custom TS T3 .82 Vband housing to suit a G30 super core, it will be $1000AUD. I’m still inquiring shipping cost
9 hours ago, GTSBoy said:
Not too bad. Horrible compared to non-twinscroll options available, but not as much as genuine. So....workable.
Probably still smarter to convert manifold to T4.
Update 3: shipping will be 100AUD.
I do think a total of 1100AUD is doable for a custom built G30-660 T3 TS .82 A/R Vband, but I’m also finding T3 to T4 TS adapters for $67AUD and a .85 A/R TS T4 housing for 500AUD.  I know the turbo would sit about 1.25cm higher (which means redoing my downpipe and intercooler piping) and two gaskets…
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
